Results 1 to 10 of 10
Thread: DIY Westminster Royals
    I'm drunk.
    Default DIY Westminster Royals
    No not by me.
    But this chap in Serbia has built his own and documented the build process. Unfortunately all the words are in Serbian (dont know how well google translate will cope), but there are plenty of pictures and a set of PDF documents for anyone else who is feeling courageous.
    Wow! RESPECT!
    iFi ZEN Stream/TV/CXC >> RME ADI2 DAC >> XTZ Edge A2-300 >> Rogers LS8a
    PC >> Hugo 2 >> iFi Pro iCAN Sig >> Raal-Requisite CA-1a
    Amazing but he should have put some of his undoubted talents towards making a decent turntable support...
    The cabinets look awesome, but they don't look like Tannoy drive units - at least none I've seen before....
    Maybe it's the funny 'foamed' surrounds?
    Turntable: Heavily-modified Technics SL-1210MK5G [Mike New bearing/ETP platter/Paul Hynes SR7 PSU & regulator mods]. Funk Firm APM Achromat with Nagaoka GL-601 Crystal Record Weight. Isonoe feet & boots. Ortofon RS-212D tonearm with Denon DL-103GL, in a Denon PCL-300 headshell, fitted with Funk Firm Houdini and Kondo SL-115 pure-silver cartridge leads.
    I'm Paul.
    I'm no expert on vintage Tannoy's but are they really going to sound that good if he's built them to the original design? I was under the impression that updating the cabinet design as per speedysteve represented a considerable improvement in SQ over the original Tannoy cabinets.
    Paul.
    The very first post mentions HPD385's
    Hi Chris,
    That's probably why then, as I'm unfamiliar with those drive units... Personally, I'd much prefer a pair of 15" Monitor Reds or Golds in there!
    I'm AMusicFanNotAnAudiophile.
    There's also the possibility that the original edge suspension on the main drive unit has brittled and perished, and you're looking at a refoamed unit
    Chris
    Common sense isn't anymore!
    Hi Chris,
    Yes, that did cross my mind - they certainly don't look like any Tannoy drive units I've ever seen
    Out of interest, does anyone know what drive units are used in brand new Westminsters?
    I'm Guy.
    Quote Originally Posted by Spur07 View Post
    Speedy Steve has been making rectangular GRF replica's. The Westminster is a completely different design.
