Results 1 to 6 of 6
Thread: basshorn finished
    Default a basshorn is born
    hi
    after over two month of work, between project, woodwork and paintjob, my basshorns got finished yesterday. it was quit hard work to bring them home. Each cabinet is sand filled, and weight is over 130 kilogram. 4 men were needed to transport them. I wanted the length of the horn not to bee too big, to avoid time delay problems. It has 1,5m length. Calculated Fc is 75hz at half space, with equalizing i am getting 50, 60hz in the room. This is about what my objective was, since i use a sub below them. I utilize a 12" JBL 2206h pro woofer, and a RAS300 plate amp to drive them.
    Was the effort worth it ? Absolutely. first listening impressions were very impressive. Extreme controlled and fast bass, and dispersion in the room is much better, than it was with the 15" direct radiator in bassreflex cab, as i used before. Now i am awaiting to finish the satellite. That should take more about one month.
    some pictures at my blog and forum :
    http://www.flickr.com/photos/12312992@N07/page1/
    http://www.audiovoice-acoustics.com/...?p=331#post331
    Angelo
    I'm BigBobJoylove.
    I'll embed the images as they look so darned wonderful!
    Lounge:
    Samsung QE65QN80F 65" QLED TV
    Echo Link streamer
    XMOS DSD Async
    Emotiva A2+ power amplifier
    Neat Motive SX1 speakers
    Van Damme 4.00mm tour grade speaker cable
    Nakamichi Fanlock banana plugs
    Studio:
    SMSL DAC
    Modified Fosi P4 preamp
    Adam Audio T5Vs
    Fenton 10" active sub
    Roxel RBS 300s
    Several valve preamps
    I'm BigBobJoylove.
    Angelo, you mention 'satellite', for someone with limited experience of horns, could you elaborate a little?
    Lounge:
    Echo Link streamer
    XMOS DSD Async
    Studio:
    SMSL DAC
    Adam Audio T5Vs
    Roxel RBS 300s
    hi Rob
    shure. I mean the 3way horn channels, covering above 150hz.
    the horns made of MDF layers, glued together, as can be seen on my blog, and then turned on a big wood lathe. Finally, grounded , and painted with PU
    Polyurethane, which gives a satin, raw surface.
    - the midbass : a round tractrix horn with 96cm outside diameter, covering from 150hz to 700hz, using a 8" high-efficiency , cone driver. SPL will be 109db/1wm.
    -the midrange : a round constant directivity horn with 56cm diameter, covering from 700hz to 10khz , usind a 2" compression driver with 111db/wm
    - the trebel : a horn tweeter, covering above 10khz, with 110db/wm
    all passive crossover, first order.
    the channels are full time aligned, that meens all drivers are vertically on axis, with each speaker and driver placed on the same distance to the listener. This way, all frequences arrive to the ear the same time, giving a more coherent , transparent sound.
    more about this on my forum :
    http://www.audiovoice-acoustics.com/...hread.php?t=89
    I'm InSpace.
    Quote Originally Posted by Angelo888 View Post
    Christ on a Bike!!!!
    That is serious sensitivity!
    Shian7
    Kudakutemo
    kudakutemo
    ari mizu-no tsuki
    Though it be be broken -
    the moon on the water.
    - Choshu.
    I'm BigBobJoylove.
    hi Rob
    Ahh I see, well they're obviously going to sound amazing (I've heard Pete's horns and there as something uncannily good about them) with all the work you've put into them - not only that, the visual appearance will be mind blowing, always a good combo! Nice work Angelo.
    Quote Originally Posted by Shian7 View Post
    Even Cerwin Vega would be embarrassed by that figure!
    Lounge:
    Echo Link streamer
    XMOS DSD Async
    Studio:
    SMSL DAC
    Adam Audio T5Vs
    Roxel RBS 300s
