| Analogue Art Turntables and all analogue SOURCE equipment and ancillaries. All discussions relating to tape, and to tape decks/RTRs, should also go here. |
Thread Tools | Display Modes |
#51
I've just read this from Dave C on another thread:
Quote:
![]() Marco.
__________________
My system: Modified Technics SL-1210MK5G/Mike New high-precision bearing/Funk Firm Platter/5mm Achromat and Paul Hynes SR7EHD PSU (with regulator modules)/DCSXL pure-silver DC lead & Yaeger (low-impedance) connector. Ortofon RS212D tonearm, with Yannis Tome 423.5 Phono Silver Litz tonearm cable (fitted with Furutech CF-DIN(R) and Eichmann silver Bullet Plugs)/Ortofon SPU Royal GM MKII. Other cartridges: vintage Shure SC35C and Stanton 500AL. Bruil record weight. Audiocom-modified Sony X-777ES/DAS-R1 transport/DAC. Nakamichi BX-125E. Heavily-modified Croft Charisma-X preamp. Ortofon ST80SE MC step-up transformer. Nick G modified Lentek MC 'head amp'. Tube Distinctions 50W pure Class A (P/P) Copper amp, with cryo-treated Tung Sol KT120s. 'Lockwood Major' speakers, using 15" Tannoy Monitor Golds, modified with bespoke crossovers. Other speakers used: Celestion Ditton 66 Studio Monitors. Stands: Mana Acoustics (non-magnetic stainless steel 'clones'). Cables: Mains Cables R Us 'Ultimate' power leads (using Furukawa EE/F-S 2mm & 2.6mm solid-core cable), with Furutech FI-50 IECs and FI-1363R 13A plugs. Mains block: Mark Grant 6-way, modded with Furutech FP-1363R sockets and Furukawa cable. Mark Grant G2000HD interconnects, with WBT NextGen-0110Ag RCAs. Oyaide FTVS510 digital interconnect, with WBT NextGen-0110Ag RCAs. VDH 'The Wind' Hybrid II speaker cable. Tube Distinctions digital noise filter. VPI HW 16.5 record cleaner. "We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines..." -- Nelson Pass |
#52
I didn't use an EMT cartridge when I had the EMT turntable here.
However, I have borrowed an EMT cartridge in the past (one of these) ![]() It was certainly powerful sounding but the HF was hard & ultimately fatiguing. I couldn't have lived with it in the long term. Personally I think I'd take an SPU, for all its foibles, every time. |
#53
That's right you had that Shure SC35C on it, didn't you?
Quote:
![]() They must be different designs? I guess that I just really like the sound of broadcast cartridges (DL-103 and such like), and to my ears in my system, the XSD-15 sounds like another very fine example of the breed ![]() Marco.
__________________
#54
Only briefly with the Shure. It wasn't great. I had 2 or 3 other MM's to try but was somewhat constrained by having to use the TT's hardwired in, mm only phono stage.
Could also have done with one of these TDU headshells really. http://www.emt-profi.de/headshell_tdu.htm |
#55
Indeed - it could well have been. I'm not sure I like the design of that headshell too much, TBH...
Another significant factor could've been that the A23 SUT also works very well with the XSD-15, as was confirmed by Shindo USA (who distribute Auditorium products), when I decided to buy the A23 and I was talking to them about SUTs for the 103, EMT and SPU - all of which Auditorium 23 make SUTs for ![]() Basically, the bottom line was that the synergy was spot-on with the combo I had in conjunction with the EMT XSD-15 in my system ![]() Marco.
__________________
#56
There are 3 visible aspects of this cartridge design which could be improved upon.
![]() A. The shape of the magnetic circuit is full of discontinuities, ie changes in profile. This is far from ideal. You really want a smooth shape without right angled bends etc. The ideal would be a round section ring with a small gap for the coils to sit in and the pole pieces either side of the coils shaped to focus the field right through where the coils sit. the more closely that can be approximated, the better the magnetic field will behave. B. the lead off wires from the coils go straight to the points where the output wires are attached. How these fine wires are 'dressed' will affect the behaviour of the coil. There are better ways of managing these wires. C. All of the EMT generators seem to need some capacitative loading to control that HF response which suggests to me that something in the design is flawed. I have heard of people having to alter the capacitative loading, sometimes adding more to get it to work satisfactorily. Not convinced that the open body is a great idea either. All imho of course. |
#57
Hey, if you say so Capt'n...
I'm afraid most of that is beyond my big daft nut!Do you know if the EMTs (specifically the XSD-15 I heard) use Alnicos? Marco.
__________________
#58
No I don't although it wouldn't surprise me given the age of the design. I think the XSD15 is just the above, but in an EMT shell with a bottom cover fitted.
However it would seem that converting an XSD15 to be universally usable is not quite straightforward. Here's an interesting write-up on ZG http://www.zerogain.com/forum/showthread.php?t=17016 |
#59
Thanks - I've have a good read through that later!
![]() I suspect that the EMT does use Alnicos, because I can hear their trademark 'musicality'. What's obvious to me is that something must be causing the difference between this: Quote:
Quote:
![]() A valid explanation must exist to explain the diametrically opposed results obtained, and I'm certain it's not simply just down to our different preferences, because generally you and I have similar tastes in audio. Marco.
__________________
#60
Quote:
It has to be remembered that EMT designed their deck, arm and cartridge for broadcast studio use. It had to be sufficiently robust and reliable to withstand the rigors of continious use for several hours a day, day in day out. This also explains why there is no adjustment of overhang within the headshell of EMT cartridges. EMT designed the arm and the cartridge as one (much as Decca did). The goal was one of consistency; each cartridge was to be as near identical to any other sample. Again a deliberate policy; should a cartridge fail in use, a replacement could be fitted in a matter of seconds, without the necessity of readjusting overhang or tracking force and bias; important in broadcast use. Quote:
I also use an XSD15 in either an SME3009 or 3012 arm. The SMEs are used because they use a sliding base to adjust overhang, as there is no provision to do this within the EMT headshell. I have used an EMT/SME combination for the last 30 years. Quote:
None of my EMTs are fitted with capacitors to 'tame' the top end. That was a development made by Roksan and by the German company Tubafon, who take nude EMT generators and modify them. Incidently I notice in the photograph of the nude EMT you tried, capacitors are fitted, yet you still found the treble hard and fatiguing? There seems to be no real consensus over the correct loading for an EMT. EMT don't fit capacitors at the cartridge. The current STX-21 transformer (10:1 step up) has a 33uF capacitor fitted inside as well as a shunt resistor on the secondary side, so effectively loading the cartridge with 171.5 Ohm, assuming a nominal 47Kohm loading by the preamp. The A23 transformer, I believe, offers a loading of 105 Ohm and seemed to work very well with the EMT. I have read of other users loading the EMT with 600-800 Ohms (800 Ohms was recomended by the reviewers in The Absolute Sound magazine). I use 100 Ohms plus 22nF. The coil resistance of the EMT is 22Ohm, similar to the 14Ohm figure for the Denon103SA. Further evidence that the A23 SUT is a good match for EMTs Quote:
If I were starting from a clean state, as you can Marco, I would retain the Jelco arm (especially as Dave C can provide the correct arm board) and procure a 'nude' EMT and fit it into the Fidelity Research headshell. I have doubts about the resonant behaviour and integrity of the EMT headshell. The EMT929 arm (with TSD cartridge ) has the following geometry: effective length (stylus tip to arm pivot), 244mm overhang, 14mm offset, 20.8 degree mounting distance (from turntable spigot), 230mm. This should help Dave C with the Jelco armboard. Quote:
Apologies for the length of this post, but being a bit of an EMT enthusiast and knowing the Marco was quite impressed on hearing my sample in his system, I want to offer as much encouragement as I can. Regards
__________________
Barry |
| Thread Tools | |
| Display Modes | |
