Results 1 to 7 of 7
Thread: SL-1200 SL-1210 bearings
    Smile SL-1200 SL-1210 bearings
    At last our own bearing is available from stock right now and we are taking deposits on Mike New's new bearing which we hope to have in stock by the end of December, that is unless advance orders are very high. You can see them here www.SL-1200-MK2.com
    Regards
    Dave
    I'm Ralph.
    Wow, it's like waiting for a bus, you wait forever and they all turn up at once! Had a look at the Sound HiFi site but could use some more info about the Mike New bearing ie., what advantages are there over the TimeStep, where did this come from etc??
    Must admit I'm very tempted by the MN, it's all that brass that does it for me, very cool.
    Cheers
    MartinT Guest
    Looks the business, Dave. When can we order?
    Smile
    As the web site says, you can order right now!
    Dave
    Hi Dave,
    Could you answer my queries on the other thread, matey:
    http://theartofsound.net/forum/showt...9223#post79223
    Turntable: Heavily-modified Technics SL-1210MK5G [Mike New bearing/ETP platter/Paul Hynes SR7 PSU & regulator mods]. Funk Firm APM Achromat with Nagaoka GL-601 Crystal Record Weight. Isonoe feet & boots. Ortofon RS-212D tonearm with Denon DL-103GL, in a Denon PCL-300 headshell, fitted with Funk Firm Houdini and Kondo SL-115 pure-silver cartridge leads.
    Cool
    Hi Marco, you need to do some work yourself!! did you click on the link
    Dave
    Yes, see my reply on the other thread!
Tags for this Thread
