Hi
I hope this is the right place for this question.can anyone tell me if the treble control knobs are just a push fit.I have tried to remove mine but they won't budge I would hate to break them .
Thanks
Vinnie![]()
I'm Vinnie.
Hi
Thanks
Vinnie![]()
Hi Vinnie,
I'll move your enquiry to the D.I.Y room and hope that someone there will be able to help[NOW DONE]
Failing that, a call to Roger at Lockwood will provide you with the info you need:
http://www.lockwoodaudio.co.uk/
I use Monitor Reds, which don't use treble controls. I presume you have Golds?
Turntable: Heavily-modified Technics SL-1210MK5G [Mike New bearing/ETP platter/Paul Hynes SR7 PSU & regulator mods]. Funk Firm APM Achromat with Nagaoka GL-601 Crystal Record Weight. Isonoe feet & boots. Ortofon RS-212D tonearm with Denon DL-103GL, in a Denon PCL-300 headshell, fitted with Funk Firm Houdini and Kondo SL-115 pure-silver cartridge leads.
Good question - I took the whole assembly out for contact cleaning and did not remove the knobs.
I would expect they are.
Let us know what you find out...
