I try to use both - get a basically sound and well engineered design and then listen to music reproduced by it to see if the heart is engaged as well as the head. Good sounding products with obvious technical flaws tend to have been "voiced" around one particular parameter, the rest not being as good as this one particular aspect - IMO currently.. This is why good old gear can stand the test of time - decades in fact - and still do the business, because the design was a well balanced one, if a little more compromised than more recent ones made with up to date components. The Quad II is a classic case in point where EVERYTHING from the wires used to the values of some critical components was taken into account. Change these at one's peril as the (technical) balance goes and the results are readily audible.....
I can't go on and I can't go back, I don't feel so matter of fact,
I tried and tried to make good sense, What's the good to try it all again?
