Closed Thread
Page 1 of 1063 12311511015011001 ... LastLast
Results 1 to 10 of 10621
Thread: Three Words Daily (Or whenever you like)
    Default Three Words Daily (Or whenever you like)
    This a version of the classic thread that used to run on Wigwam where someone writes three words designed to prompt a subsequent response from another person that relates in some way to the three words above.
    For example:
    If someone writes "Prog rock is".
    You could reply with "For big sissies" (no offence, Andre, ), or whatever else tickles your fancy!
    The object of the game is to try to construct a running dialogue that stays in context.
    Rules
    1) The subject matter is unlimited, but keep it reasonably clean and preferably witty. Anything excessively smutty will be removed by the mods or administrators, and anyone who continually breaks this rule will be prevented from posting on the thread.
    2) Always ensure that your three words relate CLEARLY to the ones above. Any three words written that don't achieve that will be removed by the mods or administrators.
    3) No more than three words are allowed per contribution. Punctuation marks are allowed if relevant. Subsequent replies to the initial contribution should be written in lower case.
    4) Once someone has contributed their three words they may not post again until someone else had replied.
    5) Remove all signatures from posts so that what's left showing is just the three words written.
    Have fun!
    I'll start the ball rolling with:
    Computer audio is
    I'm InSpace.
    pretty awful really
    unless you have
    I'm BigBobJoylove.
    an Apogee DAC
    which are fab
    on a Tuesday
    I'm BigBobJoylove.
    and every other
    leap year with
    I'm BigBobJoylove.
    a Royal wedding.
    Al-Fayed thinks that
Closed Thread
