Results 1 to 10 of 12
Thread: Tone Controls
    Default Tone Controls
    Anyone ever tried something like this passive tone control between Pre & tube amp? I've always had problems without tone controls, i think there a nessisary evil to tell you the truth..
    I'm Stu.
    I find it difficult without a balance control as years of djing and having a headphone over one ear and a monitor next to the other have taken their toll. I heard that pardon. not the same thing as the tone control but i'm ever so pleased my set up has one
    Quote Originally Posted by Vinyl Grinder View Post
    Like dropping a cat turd into a glass of Chardonnay.
    I'll ignore that one considering it's from you.
    Why?
    And why from me, you and others have had nothing but constructive and accurate advice from me.
    What I said was a perfectly good analogy. If you wish to *totally* pollute the interface between the power and the pre then do it. In fact with some amplifiers you may even get some pretty flames and smoke from the power amp to entertain you. I just looked for an analogy that expressed that level of pollution. If you wish to insert it earlier in the circuit with op amps either side, you will get something that doesn't totally pollute but only (IMO) unacceptably pollutes.
    If you don't want accurate advice but just want people to re-inforce your predudices and ego then don't make it a general question to the forum.
    Note to the mods - you see your withdrawal of that conflict you created hasn't solved it, you have left a *flavour*.
    I'm InSpace.
    Here you go, digest this little lot!
    http://www.schmarder.com/radios/tech/tone.htm
    Cheers,
    Mike.
    Since good old "LH" most of the not so young guys around here know of that circuit. And yes I dumped it around 1971.
    John
    Music is an emotional experience. Without it, living would be a dull habit...
    I'm BigBobJoylove.
    Quote Originally Posted by Richard View Post
    Why?
    And why from me, you and others have had nothing but constructive and accurate advice from me...
    ...If you don't want accurate advice but just want people to re-inforce your predudices and ego then don't make it a general question to the forum.
    Eh??
    Lounge:
    Samsung QE65QN80F 65" QLED TV
    Echo Link streamer
    XMOS DSD Async
    Emotiva A2+ power amplifier
    Neat Motive SX1 speakers
    Van Damme 4.00mm tour grade speaker cable
    Nakamichi Fanlock banana plugs
    Studio:
    SMSL DAC
    Modified Fosi P4 preamp
    Adam Audio T5Vs
    Fenton 10" active sub
    Roxel RBS 300s
    Several valve preamps
    With some of the Chardonnay around (particularly cheap New World varieties) cat turd may be preferable!
    Rob,
    Richard just likes being the 'bad boy'. Let him play
    Would that be a flavour of Chardonnay or something a touch more acid like Sauvignon Blanc? There is no lingering aftertaste on my palate.
    Turntable: Heavily-modified Technics SL-1210MK5G [Mike New bearing/ETP platter/Paul Hynes SR7 PSU & regulator mods]. Funk Firm APM Achromat with Nagaoka GL-601 Crystal Record Weight. Isonoe feet & boots. Ortofon RS-212D tonearm with Denon DL-103GL, in a Denon PCL-300 headshell, fitted with Funk Firm Houdini and Kondo SL-115 pure-silver cartridge leads.
    Quote Originally Posted by johnrtd View Post
    1971.
