Results 1 to 8 of 8
Thread: Special Offers for Technics Owners
    Default Special Offers for Technics Owners
    Selling well in the USA but maybe not as widely known about over here even though these are made in the UK, Techniboots are made by Deflex Audio and fit over your existing SL1200/1210 feet to add an extra level of resonance absorbtion, made from a soft elastomer they are a substantial item which have proven to be very popular as a fit and forget accessory for your Techie.
    Available on my website for only £39.95, if you pm me I will give you a special AOS discount code to use when purchasing them.
    I have also put together a special package for any AOS member contemplating buying the superb Jelco SA-750D tonearm, when Adam Smith reviewed it he gave it 5 stars here and the same 5 stars was given recently in HiFi Choice.
    The arm is on special offer on my website for £385.00 here which includes 50 free MoFi Record Sleeves or if you prefer a Blue Horizon Probrush. If ordering please put which you prefer in the order comments section on my site when checking out.
    MartinT Guest
    I'm running a set now. They're very good, giving incredible levels of isolation when used in conjunction with Isonoes.
    Quote Originally Posted by MartinT View Post
    Seeing your Techie and knowing the lengths you have gone to to make it what it is has almost re-invigorated me to get mine fettled but alas I just don't have the time. Nice picture and thanks for the positive comments.
    This image is hosted in my photobucket account now, sorry Martin!
    MartinT Guest
    Thanks, David. Photos from your hosting now reinstated.
    Now Martin, I have taken delivery yesterday of something "rather" special for sitting a Tech on, or indeed for sitting anything on (apart from your arse as that would be far too big ()
    I put it under the 401 this morning and fired the Canor up and as it happened my LDA phono stage had just come back so plumbed that in too, detail I never knew existed on the Jennifer Warnes "The Well" cam eout and bit me almost, I cannot divulge too much as I need to fir them under the Tech first and see what transpires, I knew there must be something to beat the Isonoes and I think I have found it.
    I'm also interested, but I would need a translation first of this into English:
    I cannot divulge too much as I need to fir them under the Tech first and see what transpires...
    Turntable: Heavily-modified Technics SL-1210MK5G [Mike New bearing/ETP platter/Paul Hynes SR7 PSU & regulator mods]. Funk Firm APM Achromat with Nagaoka GL-601 Crystal Record Weight. Isonoe feet & boots. Ortofon RS-212D tonearm with Denon DL-103GL, in a Denon PCL-300 headshell, fitted with Funk Firm Houdini and Kondo SL-115 pure-silver cartridge leads.
    fit
    too much prosseco!
