Page 1 of 9 123 ... LastLast
Results 1 to 10 of 84
Thread: Danijel's House of Sound
    I'm Danijel.
    Smile Danijel's House of Sound
    Hi there,
    I have three separate systems, for every room that I spend some more time in: Living/listening room, working room and a bedroom.
    Every system that I have are based on Sony's Digital Drive, S-MASTER PRO amplifiers, whose sound I loved "on the first listening", and now I just can't live without .
    Living/listening room:
    components:
    -Sony STR-DA7100ES receiver (I'm after one or more TA-DA9000ES multichannel amplifiers, and this DA7100ES goes to working room)
    -Sony DVP-NS9100ES SACD/DVD universal player (i.Link (fire-wire) linked to STR-DA7100ES)
    -Sony PS-6750 turntable w/Denon DL-103R cartridge
    -SimAudio Moon LP3 MM/MC phono stage
    -Sony ST-SB920 tuner
    -Sony MDS-JB980 mini disc recorder
    -Sony TC-KB920S compact casette deck recorder
    -Sony RDR-HX900 DVD/HDD recorder
    -Sony SLV-X9 VHS casette recorder
    -Sony PT-79R program timer
    -Sony RM-AV3000 universal remote controller
    -HTPC PC in Antec case (soon to be replaced by hfX Classic case w/totally passive cooling)
    -Belkin PF-50 power line conditioner/filter
    -LG 60PZ250 60" 3D plasma display
    speakers:
    -Sony SS-X90ED x2, main speakers L & R
    -Sony SS-X70ED x5, center, surround and surround back speakers
    -Sony SA-WX900 x1, subwoofer
    cables:
    -Neotech speaker cables
    -Glass fiber optical cables
    -Neotech coaxial cables
    -Neotech analog audio cables
    -Oehlbach XXL analog and digital video cables (HDMI, Component, Scart)
    -Neotech power cables
    -Belkin Pure AV Silver i.Link cable
    I plan on changing the MDF shelves and speaker bases with marble shelves and bases (Actually, I'll probably change the stands altogether). Also, I plan some acoustic room treatment (acoustic foam, bass traps,...)
    And here are some pictures for your pleasure (some of them are older than others, the newest are on the bottom):
    I'm Danijel.
    Working room:
    components:
    -Sony STR-DB2000 receiver (will be replaced with Sony STR-DA7100ES receiver, as soon as TA-DA9000ES arrives in Living/listening room)
    -Sony DVP-NS900V SACD/DVD universal player
    -Musical Fidelity V-Link II Asynchronous 24bit 96KHz USB to SPDIF Converter
    -Belkin Power surge Gold series power line conditioner/filter
    speakers:
    -Sony SS-X30ED x2, main speakers L & R
    -Sony SA-WD100 x1, subwoofer
    cables:
    -Oehlbach analog audio cables
    pictures:
    I'm Danijel.
    Bedroom:
    components:
    speakers:
    -Sony SS-X70ED x2, main speakers L & R
    -Sony SS-X30ED x2, surround speakers
    -Sony SS-CNX70ED x1, center speaker
    -Sony SA-WX700 x1, subwoofer
    cables:
    -Oehlbach speaker cables
    -Oehlbach i.Link cable
    ...and again, some pictures:
    I hope you like them
    Cheers,
    Danijel
    You like Sony kit then!
    That is an impressive array of equipment AND systems! Most of us only get away with one, not three.
    I believe the classic Sony DD turntable will be well appreciated, so a very warm welcome to AOS.
    Steve aka 'Twelvebears' (it's a long story)
    System: Technics 1210 Mk5, Jelco 750 arm, AT33EV via MF X-LP2 Phono Stage, Oyaide mat and record clamp. SB Touch via Marantz PM-11S1 amp and Wilson Benesch A.C.T. speakers. Mark Grant cables and PS Audio Power Plant Premier mains regenerator.
    (\__/)
    (")_(")
    Hi Danijel,
    Looks like a superb room and system. However, when I click on any of the images, to enlarge them, I can't do so, as it comes with "The web address you entered could not be found".
    I notice that you're using a image hosting site called 'postimage.org', which I'm unfamiliar with. We normally use Imageshack or Photobucket, on AoS, which always works.
    Therefore, is there any chance you could upload your pics instead using either Imageshack or Photobucket, so I can enlarge your pics and see them properly?
    Cheers!
    Turntable: Heavily-modified Technics SL-1210MK5G [Mike New bearing/ETP platter/Paul Hynes SR7 PSU & regulator mods]. Funk Firm APM Achromat with Nagaoka GL-601 Crystal Record Weight. Isonoe feet & boots. Ortofon RS-212D tonearm with Denon DL-103GL, in a Denon PCL-300 headshell, fitted with Funk Firm Houdini and Kondo SL-115 pure-silver cartridge leads.
    I'm InSpace.
    Love the AV system, very nice!
    Shian7
    Kudakutemo
    kudakutemo
    ari mizu-no tsuki
    Though it be be broken -
    the moon on the water.
    - Choshu.
    Have you tried enlarging the pics, Mike. If so, are you able to? I can't here...
    I'm InSpace.
    They work just fine for me!
    Shian7
    Kudakutemo
    kudakutemo
    ari mizu-no tsuki
    - Choshu.
    Mmm... Dunno what's wrong, then. I often have that problem, when pics haven't been uploaded via Photobucket or Imageshack...
    Yep, confirmed, fine for me too.
    Looks like the interweb is picking on you Marco!
    (\__/)
    (")_(")
