Results 1 to 7 of 7
Thread: Cork & Vinyl Platter Mat.
    I'm Paul.
    Default Cork & Vinyl Platter Mat.
    I needed something a bit thinner on my platter as the rubber mat I was using was too high. I quite liked the mat as it produced no static at all and sounded very good. I prefer felt but can stand the static it generates which then causes problems with noise and dust that just gets irritating.
    I peeled some 1mm thick cork from its cardboard backing from a cheap pin board. I stuch a layer of the cork on an old cheap, thin record that was flat.
    I have to say its very good
    The old record?? well it was Azwad, Too Wicked EP. When I first played it, it was so bad I thought "Don't turn around" but now it has a new lease of life.
    ~Paul~
    I'm Nick.
    Quote Originally Posted by Primalsea View Post
    Sometimes you've just "Gotta Find A Way"
    [SIZE="1"]Nick
    Follow AOS on Twitter: @AoS_Forum
    Who remembers Azwad when they were good, well before their 80s chart twaddle?
    I'm Nobody.
    I used a varnished Cork platter mat for yonks on a Garrard '401' was greet.
    I'm ChrisB.
    From The Grave
    I'm Nobody.
    There's me saying a bit back i've not used a cork mat before when i really had i'd forgotten it was indeed a loricraft mat, i forget now what diameter it was, if anyone knows tell us..
    Location: Bristol, since 1978. Current house since 1996!
    Smile Cork
    Cork is my secret weapon in hi-fi! Use CORKS as 'Stillpoints', for example. Plus you can dampen vibration on cables (if you think it matters) with split corks. Also use as turntable support/amp/etc.
    It has great characteristics . Was even used on a Space shuttle.
    And I love Iberian cork oak forests........
    Chris.
