Results 1 to 10 of 11
Thread: What Cartridges
    I'm Nobody.
    Default What Cartridges
    Have you enjoyed using the most?
    I'm not a Moving Coil fan, never have been but i did like a couple of High Output Denons, other than that a MM Man.
    Denon 'DL110'/'160'
    Grace 'F9E'
    Nagaoka 'MP11 Boron'
    Goldring 'G900IGC'
    Pickering 'XLZ-7500S'
    ADC 'XLM/3
    JVC 'Z1'
    DL110
    Goldie 1042
    quite like the DL103 through my SUT (only have MM input)
    Steve.
    Kit I have:
    CD player, TTs, Phono stages, Pre amps, Power amps, Integrated amps, DACs, Streamers, Speakers and a bunch of cables.
    I'm Adam.
    Audio Technica AT-110E - the amount of performance you can get out of this is absurd.
    Decca Deram - sounds far better than a ceramic ought to!
    Ortofon OM Pro S - they cost about £30 each and are meant for DJ use but are surprisingly capable in hi-fi terms. 3-4g tracking weight also means they can be used on older, massier arms.
    Ortofon 2M Black - the finest MM I have ever heard that wipes the floor with most MCs up to £1000 or so, IMHO.
    Audio Technica AT-OC9MLII - I may have the above 2M Black and a Kontrapunkt b MC (which is also brilliant) but I keep coming back to this one.
    MartinT Guest
    Empire 2000E/III
    Shure V15-II
    Ortofon MC-20 Super
    Ultimo 10X
    Dynavector 20A
    Denon DL-160
    Audio Technica AT33PTG
    Dynavector 20X2L
    I'm Stuart.
    Grace F9E Ruby
    Stanton 681 EEE
    Denon 103R with Soundsmith alloy cantelever and eliptical tip
    Ortofon MC20 with Garrott retip
    I'm John.
    Ortofon VMS 20 and 30
    Ortofon M20 FL
    Ortofon MC20 Super
    Signet MK 111
    Sumiko Blue Point Special
    Ortofon Rondo Bronze
    Dynavector DV 20
    Lyra Dorian
    Denon 103R
    Ortofon 2M Black
    And agreeing with Adam about the 2M Black. A fabulous cartridge.
    Sent by me using an appendage
    SME Model 15/V tonearm, Sumiko Starling, Dynavector P75IV.
    Luxman 509X amp.
    PMC 25 23i speakers.
    Innuos/Roon/Qobuz/I-Pad. Oppo UDP-205.
    Cables by Kimber, Yannis and Audioquest.
    Audioquest Niagara. Tube Distinctions Mains power filter. Project RCM. Zerostat.
    Over the past forty years I've probably had direct (that is, heard in my system at the time) experience of some twenty cartridges, both moving coil and fixed coil.
    These are/have been (an asterisk denotes cartidges no longer in my possession), in rough chronological order:
    Shure M3D (*)
    Shure M55E
    Shure V15 II improved (*)
    Shure V15 III (*)
    Ortofon SL15E
    Ortofon SL15E/II
    Ortofon MC20 (*)
    Decca Mk. V (x2)
    Decca Mk. VI
    EMT XSD15
    EMT TSD15 (nude)
    Linn Asak
    ADC10E IV
    AKG P8ES (*)
    ADC 25
    ADC 26
    Grado FTE+1 (*)
    EMT TSD15 FLS
    EMT TSD15 (sph)
    B&O SP6
    Denon DL103 (x2)
    I have also spent time with the following (again in rough chronological order):
    Shure M31E
    Adio Technica AT66
    JVC X-1
    Goldring Eroica
    Ortofon MC25FL
    and
    Sumiko Blue Point Special.
    Bearing in mind the fallability of aural memory and recognising that one's tastes change with time (and finances!), of those I have listed the following
    have given me (and continue to give me) the most pleasure:
    Shure M55E
    Ortofon SL15E and SL15E/II
    All Deccas
    All EMTs
    AKG P8ES
    and, because it was such amazingly good value for money, the Grado FTE+1.
    I miss the AKG P8ES; it was great for rock 'n roll. I loaned it to a friend who later claimed to have lost it! Does anyone have one they want to sell me?
    Biggest disappointments for me were the Linn Asak and the Sumiko. There was nothing technically wrong with these two; they just didn't engage me.
    I'm Cliff.
    Denon DL A100, Shindo SPU, Miyabi 47---in no particular order.
    Gosh, I've had so many cartridges over the 30+ years I've been into 'serious' hi-fi (into the hundreds), I couldn't begin to remember them all!
    However, the ones I've enjoyed most (that I can remember), kind of in date order of when I used them were:
    Original Nagaoka MP10 (or 11 - can't remember - which one was out in the early 80s?)
    That gorgeous sounding vintage Technics P-mount design everyone raves about now. Can't remember the model number?
    Linn Trak.
    Linn Karma.
    Supex (something or other low-output MC, can't remember the model - again it was out around the mid 80s, and quite highly regarded).
    All the various Denon DL103s (over the years, I've had them all). My favourite was the 'SA'.
    Koetsu Red Signature.
    AT-33PTG.
    Koetsu Black Goldline.
    Ortofon Rondo Bronze.
    I'm sure there's more, and when I remember them, I'll pop them in
    And of course all the cartridges I currently use:
    Ortofon SPU GM classic, DL-103, Goldring G800, Shure M3D and Pickering XV-15 625E.
    Linn Trak.
    Linn Karma.
    AT-33PTG.
    Would that be the EPC 205 mk3 ? I heard one in my QL1 ,back in January
    My Cartridge history , such as it is
    Ortofon OM10 , upgraded to the OM30 stylus .
    A&R P77
    Linn K9
    Linn Troika , Retipped by Len Gregory or ESC
    the only genuine MC i have ever used , though i also owned a clapped out AN IO original Kondo version , given to me as a gift by my good friend Paul.
    Music Maker MK1
    Goldring 1006
    All sold on ,but currently own ...
    Denon DL160
    AT 95HE LPgear stylus
    P-Mounts
    Technics P22/Jico SAS stylus
    Technics P24/LPgear Hyper elliptical stylus
    AT3482
    The best cartridge of the lot ? Well i would have to say the Troika after its rebuild , but the one i have enjoyed the most and has surprised me the most , giving more performance than i would have expected is the Technics P22/SAS in the QL1 , where it belongs too
    I would dearly love to get hold of a 205mk3 though , another cartridge i quite fancy is one of the pickering's with the stereohedron tip .
    Chris
