Page 37 of 47 FirstFirst ... 273536373839 ... LastLast
Results 361 to 370 of 465
Thread: Classic hi-fi components
  1. #361
    I'm Imjustsurviving.
    Quote Originally Posted by Andre View Post
    Nice one Jon
    I use an original Trio KA2000 circa approx 1970 (as per avatar) love it
    I thought you would find this interesting Andr'e, i put it on this evening in my office system having been given it last night to try out and was pleasently supprised, i'm only playing Spotify from the head phone socket on the PC whilst trying to do paper work but the sound was nice and relaxing, it certainly gave my ears a rest from the "T" amp
    Jon
    A person who never made a mistake never tried anything new.
    Set up
    Lafayette el84 power amp , Audio note M1 pre , Tannoy Sterlings, Garrard 301 , SME 3012 , puresound P10, Ortofon SPU, Cambridge CXN streamer
    Micro mega Duo 3 cd transport ,
  2. #362
    Quote Originally Posted by BTH K10A View Post
    I'd definitely be interested in seeing a picture of that driver
    Here you are - any suggestions as to what it is and why there is an aperature through the centre?
    http://s772.photobucket.com/albums/y...nknown%20make/
    Cheers,
    TD
  3. #363
    Linky no worky David
    Bests, Mark
  4. #364
    I'm Clark.
    Quote Originally Posted by Tweedle-Dee View Post
    Here you are - any suggestions as to what it is and why there is an aperture through the centre?
    http://s772.photobucket.com/albums/y...-Dee12/Vintage
    Cheers,
    TD
    Hi David
    Can't get the link to work. Comes up "page not found"
    Andy
  5. #365
    I hope the link is fixed now -sorry
    Cheers,
    TD
  6. #366
    Looks like the horn that screws to the front is missing unfortunately. Apparently you might have the driver or at least the casing. Some kind of 2" or so dome was used as a tweeter by the looks of it...
    Interesting....
    Bests, Mark
  7. #367
    I'm ChrisB.
    Could it be a hole where a tubular heat sink used to go a la Hartley speakers?
  8. #368
    I'm Clark.
    It's a Parmeko LS-1 but is missing it's diaphragm and multi cell horn for the HF compression driver. Unfortunately the diaphragm is rarer that rocking horse sh*t.
    The BBC LS1 monitor used one of these supplemented with a Lorenz LPH-65 cone tweeter to fill in a dip in the response curve where the 605 line frequency is.
    P.S. If you don't want it I'll gladly take it off your hands
  9. #369
    Yes, the Parmeko LS-1 was used in the BBC designed loudspeaker, the LSU/10.
    Introduced in 1950, only 500 units were made for the BBC. No units were ever made for domestic use. A pair of LSU/10 speakers recently went on eBay for ~ £12,000.
    The LSU/10 originally consisted of the afore mentioned Parmeko LS-1 mounted in a BBC designed cabinet, designated the LB/8. It was often driven by a modified Leak "Point One" amplifier, later known as the Leak TL12 (using KT66 output tetrodes).
    The Parmeko LS-1 was a copy of the Altec 604 design, and had a frequency response that dropped off rapidly beyond 7.5KHz. This was sufficient to monitor AM broadcasts and the playing of the 78s of the time, but was unable to detect the line scan frequency of 405 line TV. To overcome this limitation, the BBC chose to fit the Lorentz LPH 65 super-tweeter into the LB/8 cabinet, with the Lorentz unit directly bolted to the cabinet grill. It was always intended by Parmeko that the LS-1 should only be used for frequencies < 1200 Hz.
    The LSU/10 was 'pensioned off' in 1962; being replaced by the LS5/1, though a few units remained in use.
    The Parmeko LS-1 units were only supplied to the BBC for a year.
    Amazing - scarily amazing - thanks guys for identifying this. Now I just need to work out what to do with it!
    Cheers,
    TD
