Results 11 to 20 of 25
Thread: How do I service my bearing ?
    Th spindle won't pull, as there's a retaining clip on the spindle to stop it being pulled pulled out.
    You need to dismantle much of the deck to get at the bearing.
    I'm certain that Technics didn't intend for owners to dismantle the deck to lube the bearing, so I'd remove the platter and pull the spindle gently upward until it stops.
    I'd then apply a few drops of oil where the spindle enters the main bearing housing.
    Spot on Chris
    Chris
    I'm John.
    a customer sent me details of the job
    details below
    Johnnie supplied me with a few vials of booster oil.
    the oil can be applied in situ. but to totally remove and replace the old fluid and therefore reap the ultimate benefit - the bearing must be removed.
    here is how to do a full clean and change:
    https://j7rewires.co.uk
    And visit my face book page--- check out J7 Rewires
    https://www.facebook.com/profile.php?id=61557054222982
    I'm John.
    remove the centre screws and lift the pcb. the bearing will now lift out. there is a circlip at the base of the bearing - remove. clean off all original oil with supplied cloths and buds.
    then
    apply the new oil. re-fit, re-connect and enjoy
    imo, the main bearing didn't seem a great design so the slippery oil can only help
    Mike_New Guest
    Quote Originally Posted by Johnnie7 View Post
    then
    In actual fact, a thicker oil maybe the ideal when used on the standard bearing. There is so much looseness and 'play' between the simple stainless steel spindle and the brass insert that allmost any oil will do the job.
    All the BS that I read about very special (and expensive) oils for the standard techie bearing is just that, and makes me spill my wine with laughter.
    imo, the main bearing didn't seem a great design so the slippery oil can only help...
    It's built to a price, dude. Replacing it with one of Mike's superb bespoke high-precision bearings is therefore, IMO, mandatory, if you want the Techy to sound like a genuinely high-end turntable.
    Mike, I could do with some more oil for my bearing (as the bloody cat got hold of the last lot you sent, and somehow managed to spill it all over the floor! )
    Could you send me some, mate? Churz!
    Turntable: Heavily-modified Technics SL-1210MK5G [Mike New bearing/ETP platter/Paul Hynes SR7 PSU & regulator mods]. Funk Firm APM Achromat with Nagaoka GL-601 Crystal Record Weight. Isonoe feet & boots. Ortofon RS-212D tonearm with Denon DL-103GL, in a Denon PCL-300 headshell, fitted with Funk Firm Houdini and Kondo SL-115 pure-silver cartridge leads.
    I can just see that cat of yours looking inquisetively at your SPU and poking and prodding it , you know how cats do
    Cheeky little buggers .
    Chris
    Mike_New Guest
    No Problem Marco,
    You meean to say you have got some oily cat poo!!!!!
    Lol... They didn't eat the oil (thankfully) - just decided to chase the syringe around the house, as a play thing! My fault for leaving it out on the kitchen table, after using it.
    Cheers, mate. You've got my addy, haven't you?
    P.S Chris, the cats don't get near my listening room - way too dangerous, for them (with valves switched on), and my stylus
    I was only joking ,but its funny how interested cats are when they come across a valve amp (switched on)
    Chris
    I'm Allen.
    The most fun I EVER had with a cat :-
    1 Cat
    1 Laser pointer ( Red dot type )
    = hours of fun and one knackered cat
    It was my sisters cat , even she had a go and could not stop laughing
