Page 13 of 16 FirstFirst ... 31112131415 ... LastLast
Results 121 to 130 of 160
Thread: MY System
  1. #121
    I'm King.
    AR tonearm – it was made by Jelco, the same as Mission 774 LC and Jelco 250ST.
    Mission 774 LC
    King
  2. #122
    Hi King,
    Yep, the family resemblence is definitely there!
    One wonders just how many products with a 'hi-end' badge were actually made in Japan by companies like Jelco, and how some of their owners would feel if they knew...
    Which turntable do you use with the 'Mission'?
    Turntable: Heavily-modified Technics SL-1210MK5G [Mike New bearing/ETP platter/Paul Hynes SR7 PSU & regulator mods]. Funk Firm APM Achromat with Nagaoka GL-601 Crystal Record Weight. Isonoe feet & boots. Ortofon RS-212D tonearm with Denon DL-103GL, in a Denon PCL-300 headshell, fitted with Funk Firm Houdini and Kondo SL-115 pure-silver cartridge leads.
  3. #123
    I'm King.
    It is the AR "The Turntable" being used as the platform.
    King
  4. #124
    I'm King.
    Grace 707 mk2
    Grace 747
    JVC UA-5045
    Linn Ittok
    King
  5. #125
    Great pics again, King!
    As far as I'm concerned, the Grace was the best tonearm the LP12 ever seen...
    Fit a Supex and you had a match made in heaven - much better than any of the overpriced bollocks Linn are making nowadays!
  6. #126
    I'm King.
    Hi Marco,
    I had been using this classic combination for quite a period many moons ago, thanks to Linn!
    My current set up (Ittok and OC9) has been my second devotional attempt in the pilgrim’s progress, thanks to Linn again!
    The Grace 707 is a very good arm but the cable is not. I am now using a tonearm cable which I bought from the US two years ago and it is a vast improvement over the stock one.
    King
  7. #127
    Yep... Cables are one area in hi-fi where 100% of the time what's modern is better than anything from 30 years ago!
    It's often the case though that vintage tonearms (providing that they're operating optimally in a mechanical sense) are superior to many examples being made today; often a simple rewire results in superb performance and the owning of a veritable bargain.
  8. #128
    I'm King.
    Project Debut
    SME Series 3
    King
  9. #129
    I'm King.
    Audiocraft AC3000 Silver Ltd
    Micro Seiki MA505S
    King
  10. #130
    I'm King.
    SAEC 308L
    King
