Well, here goes! Opened a PhotoBucket account and i will now attempt to upload some pictures here.
The first is my complete system (excluding Speakers)
The Turntable is a Pioneer Direct Drive Motor (PXM-030, robbed from a scrap 80's deck!) mounted on a Perspex Plinth with a Rega R-200 Arm, normally (but not pictured here) fitted with my Denon DL-304
The second 'box' down is the Phono EQ. MDF cabinet with Mahogany Curl Veneering (applied by me! That was the hard bit!) using two ECC82's per channel with Passive equalisation. A slightly enlarged view is here:-
My normal Amp is an EL33 based Single-Ended design fairly close to the Mullard 3-3 circuit but tweaked slightly to accomodate the 33's and to try and get the EF86's a little quieter.
I switch between the EL33 Amp and a Mullard 3-3 i made, just as the fancy takes me. They both sound very different, i can't say i prefer one over the other, they are just different. Here's the 3-3:-
I also now and again use a Mullard 3 Watt Economcal Stereophonic Amplifier i made, only about 1.5 Watts (due to the H.T. supply) but all made from second hand components (apart from the casing) and sweet nonetheless:-
Well, that's it for now, i will perhaps post some better 'shot' photos when i get around to taking them which means when i get around to moving the kit around, which maybe this October when i have to move House.
James.
