Anyone know of anyone that builds passive crossovers?
Or any suppliers of "decent" 2 way boards?
I need a pair of 50Hz, 24db, 200W crossovers. Although, I may get away with 150W ones.
How about going active with a Behringer? You could get a CX3400 for about 70 quid.
Bests, Mark
Hmmmmm.................
12db slope might work. Its hard to go active with an integrated.
It could be done
Your biggest inductor would be around 72mH which is big, but not impossible.
I’ve wound a 60mH before
The main problem comes with the caps (480uF something) looking like your largest value. A 5 cap build with say
http://www.parts-express.com/pe/psho...Number=027-447
So, no it isn’t quite as ridiculous as it would first seem but it will cost and it will be a very big build
Single spur balanced Mains. Self built music server with 3 seperate linear PSU, Intel i5, 16 GB RAM no hard drive (various Linux OS). Benchmark Dac2 HGC, single ended XLR interconnects/Belkin cable. Exposure 21RC Pre, Super 18 Power (recap & modified). Modded World Audio HD83 HP amp. Hand built Monitors with external crossovers , Volt 250 bass & ABR, Scanspeak 13M8621 Mid & Scanspeak D2905/9300 Hi. HD595 & Beyer 880 (600 ohm) cans.
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts.
-Bertrand Russel
John.
Not impossible no But to get the resistance as low as possible to actually make the thing worthwhile ferrites are out of the window & you'll need to be looking at E & I laminations on something like a 200VA transformer core with the EI gapped to avoid saturation. So that 4 lots of 200VA transformer cores & bobbins (assuming a stereo crossover) as well as the capacitors
Bests, Mark
Prolly cheaper to buy another amp and go active.
Go on Mark, you know you wanna give it a try
Wind the inductors for him and he’s in business.
-Bertrand Russel
John.
Why is it hard to use active sub with an integrated? Or did i miss read something
