I think the coin on the headshell is worth trying. Use bluetac to attach, reset tracking force and see if that helps at all.
I'm Nick.
Nick.
Hi Lurcher,
I had to do exactly that with my Grace unipivot, add a five cent piece, that was while running the Ortofon MC. It made a world of difference, but particularly in the low frequencies.
Hi Marco,
I never ran my SF Phono 1 with the Ortofon, I loaned out the tubes to a buddy...and never saw them again. Anyway, I was running the Ortofon with a 640p, and quite well, and was of course trying other Phonostages while tweaking out my system.
The arm is as near mint as can be found...and although I'm not as steady as I used to be (and it's not the beer), I did go through the arm in detail when I got hold of it to ensure all was well. Plus I ran the Ortofon on this arm for a bit, it was quite stellar.
I am familiar with the 103 and 103R, I very much like the sound, but something is just not right here. And that I have 2 (really 3 including the 640p) phonostages in home and the problem is the same with each......
This weekend I'll bring my table up into the kitchen where the lighting is better (my mancave is poorly lit, intentionally, I can catch the wife more easily when she can't see) and go through the entire setup again.
The most discouraging thing is I think I know how good the Denon and the Lux (with the FR-14) should sound.
If you think of anything else, not including "it will sound better after 3 shots of whiskey" (I already posed that one to myself), please throw it at me.
Now I'll go back to thinking about....boobies!!!
Rick.
Kenwood KD-650 w/ Denon DL-103 (wood body, Soundsmith elliptical retip), Lite Audio DAC-83 & LT-1 Transport, Luxman M-05 Pure Class 'A' Amplifier, Luxman C-05 preamplifier, Yamaha NS-1000M (beautifully refinished and upgraded) on custom made wood stands.
I once met a woman who would put up with me...so I married her!
Please let me build a system that is a bit forgiving on what I find in thrift shops for a handful of pennies and still is able to deliver the goods on good pressings.
Hmmmmmm , not 100% sure about this,but isn't the Fidelity Research arm a lightweight one,made in the 70's for high compliance cartridges? If that is so,then.it is a complete missmatch for the Denon.It's the same reason why a Grado signature gold isn't working well with most of todays arms.
Indeed. Martin, you heard my 103SA in your system the first time I came round. Did it sound anything like Rick describes?
Hope you get it sorted out, Rick, so keep us posted
P.S You need to add "Rick" somewhere on your signature, so people can see at a glance what your name is - cheers!
Hi I know this may seem obvious, but have you tried cleaning the stylus THOROUGHLY .
The reason I mention this is, I bought a 103 off ebay and had the the problen you are describing, I nearly chucked the cartridge out thinking it was crap.
the stylus looked clean but when I ran a brush with a drop or two of ispropol over it, well what a difference, it cleaned up the sound beautifully.
Well worth a try, before you pull your own hair out.
Darrell.
Di Do Do Dat Doh Don't Di Doh..Di Do Doh..Don;t Di.
Hi Rick
I know these problems. It`s hard to stay calm.
But listen in a relax mood and try different things: order a heavy headshell. the arm has not enough mass for Denon 103SA. the real optimum you only find with heavy arms. Then also try to make tonarm a little bit higher or lower but in steps of 1 millimeter only and listen always same vinyl and at same volume.
a SUT can also help. A used fidelity research or a self made Lundahl. but this are additional costs but worth a try.
If nothing helps and you are sure to get crazy next time or drink too much whiskey:
If you can let 103SA go, the sell it and try for example Ortodon Rondo bronze or SPU classic N- naked!! with a heavy headshell.
Knut
Knut.
Acoustic Signature Thunder & Final Tool, Technics SP15, Ampearl RE1030 Valve Phono, Ampearl Valve phono LCR RE2030, Ampearl RE1031, Tribute SUT, Aidas MC, Linn Akiva, DS Audio E1, Nagra VPS
Legat Audio SETA E130L SE, Legat KT88 SE , K&T Donar, JE Labs Open baffle with Philips 12202, BK elec SUBs P12 & XXls400
I'm Adrian.
