Page 1 of 8 123 ... LastLast
Results 1 to 10 of 71
Thread: Trans-Fi Salvation World Premier Review
    I'm Clive.
    Default Trans-Fi Salvation World Premier Review
    Finally it’s time for me to write up my thoughts on the Trans-Fi Salvation rim-drive record deck. Salvation is available in 2 forms, both come with the T3Pro arm included, the variance is down to the platter; for around 1,800 you get an acrylic platter, for around 2,200 you get a 9kg aluminium platter. I say “around” as the exact price is currently being finalised.
    Trans-Fi products are no-nonsense. Boris Johnson, London’s mayor, would no doubt say there’s a complete lack of flimflam. Vic is Mr Trans-Fi; his philosophy is to build affordable high-performance products to a necessary and good level of engineering but he avoids turning his products into audiophile jewellery. Solid engineering based on performance-based principals is the mantra.
    As both a designer and seller he is able to take his products to market without adding distributor and dealers margins or even VAT, at least for now, but sales of the deck may change the VAT situation, so it you want one don’t delay! Vic is an enthusiast who like most of us is searching for ways to produce the best sound. He designs and then initially tests his ideas out with parts he makes in his home workshop. When it’s time to make production parts they are outsourced to local machine shops, to be made in batches of 10 or 20 on CNC machines. The machine shops have varying demands placed on them so fighting to get parts delivered in time is a constant battle. When the parts are ready arms and decks are then checked and assembled personally in his workshop. You should not expect a new Salvation to be available from stock; this is a build-to-order item. Depending on the batch production cycle your order could take a few weeks to be fulfilled or you could be lucky and take delivery very quickly. If Salvation were available from dealer stock and all the additional margins added this 2,200 record deck would more likely cost in the region of 5,000 to 6,000. It would still good value but I for one am very pleased that Vic chooses to avoid this route.
    If you visit http://www.trans-fi.com/turntable.htm you will get a flavour for the journey involved in producing the Salvation record deck. He has used Garrards, Lencos & Michells to name but a few, he has then modified them and improved them. He’s gained a fantastic knowledge of what works and what doesn’t. Rather than improve existing decks he found he finally had to bite the bullet and produce an entire new deck to achieve the level of performance he was aiming for. Every aspect is critical for performance and deciding on how to manage the power for the motor is probably one of the most critical along with the characteristics of motor chosen for the deck. Ultimately a lack of digital or feedback control in the power supply was found to give clear sonic advantages.
    Previously I’ve reviewed the Trans-Fi air-bearing arm at www.enjoythemusic.com. The arm has since evolved into the T3Pro. Most developments are evolutionary and can be fitted as upgrades. Vic will not stand still, instead choosing to constantly refine his designs, though the T3Pro arm and Salvation record deck have probably reached the point where further evolutions will now be relatively rare. Then again he always has the ability to surprise me with his inventiveness so keep tabs on what he’s doing!
    T3Pro arm with Tomahawk wand and London Reference cartridge:
    The Trans-Fi Salvation is a rim-drive record deck which includes the astoundingly excellent T3Pro air-bearing arm. The arm is available separately at 770 in the UK including air pump and smoothing tank, it’s 740 for non-UK purchasers who are better sourcing the generic pump and tank locally. The arm offers a super- clean, transparent and consistent sound. Not only does this parallel tracking arm banish distortion which pivoted arms have inherent in their nature in all but 2 positions across the record, but also the T3Pro is far easier to set up accurately vs pivoted arms. You have to suspend your experience of setting up pivoted arms and revel in the simplicity of set up with the T3Pro. The beauty of setting up this arm is that you set it up in sequence. I hate pivoted arm setups where you move the cartridge fore and aft and often accidentally twist it in the headshell so you end up changing the alignment in two planes at once. None of this palaver exists with the T3Pro, simple sequential setup which is easy to do very accurately.
    The T3Pro is the culmination of significant evolution, the original arm being based on Poul Ladegaard’s ideas. Since then the arm has been developed to sport an inverted air-bearing, VTA adjustment on-the-fly, simple levelling adjustability via 2 thumbwheels and it has the latest Tomahawk wand. The inverted air-bearing was a big step forward as was the shortening of the wand. The arm used to be positioned behind the platter, it is now positioned over the platter with the pivot to stylus tip distance being around 68mm, you can fine tune this distance for your deck and cartridge combination. The short laser-cut aluminium Tomahawk wand brought a significant improvement to all aspects of bass performance as well as overall clarity and definition. The wand is adjusted by sliding it fore and aft in the bearing holder; azimuth is simply set via a few turns of the mini-spikes which support the wand. Threaded counter-weights allow easy adjustment on tracking force.
    The arm is very different to pivoted arms and I’m a total convert in case you’d not noticed! The need for an air pump and smoothing tank to smooth out the air pulses is of course a difference from a pivoted arm. The air pump is an aquarium unit, the air setting required is usually very low but even so the sound emitting from the air pump means that you need to find somewhere suitable to locate it. The two most common approaches are in a cupboard or in the next room. If placed in a cupboard you may need to place the pump in a box too, allowing for some air circulation. As my listening room is in our cellar (‘basement’ for our US brethren) I have been able to take the power cable and air tube into the next room, the 5 litre smoothing tank is beside the pump. This is perfect. As these items are meant to be hidden away Trans-Fi very purposely used low cost components which are ideal for the job. Some arm manufacturers would have engineered a special pump and tank adding 500 to 1,000 pounds to the price.
    You soon get completely used to the different way of setting up and using this parallel tracking arm and you start to wonder why all arms aren’t made this way. It all seems so logical but then again that’s the product of thoughtful design and development. Considering that record masters are cut with linear tracking arms it clearly better to play them same way. Easy and accurate setup, no end –of-side distortion, alignment is spot-on through the entire record, not at just 2 points and you get a totally consistent sound. Traditional arm resonant frequency issues seem much reduced too. I’ve used various moving coil cartridges, 3 types of Londons (aka Decca – Super Gold, Jubilee, and Reference), there are many people using Denon DL 103s and SPUs, some add weight to the “saddle” which sits on the air manifold but in truth this does not seem to be necessary. When using the arm on other decks you will find the air decoupling inherent with this design very useful, it doesn’t mean there are no decoupling issues to think about regarding arm boards but they become much less critical. What is critical, well important anyway, is levelling the arm. The horizontal resistance of the arm is practically zero requiring the arm to be level – this is a good idea for any arm anyway. It’s a cinch to adjust for level via the 2 small thumbwheels on the side of the arm. Finally you have a couple of options for tonearm cable, copper litz or silver screened. I use the silver screened wire as my London cartridges are prone to hum and this wire kills any hum stone dead.
    There’s loads of information at http://www.trans-fi.com/terminatortonearm.htm and other pages on the Trans-Fi site. This is the most neutral arm I’ve heard and it’s one that extracts maximum detail from the grooves without adding its own distortion. It really is a high-end bargain.
    On-the-fly VTA adjustment:
    [/QUOTE]
    I’ve been in the highly privileged position of being a beta-tester for the Salvation deck for over a year. A record deck may have relatively few parts but all these parts have to work in harmony and sympathy with each other, believe me when I say that Vic obsesses about getting details right.
    Your Salvation will arrive in a flight case which will be picked up by courier once you have your deck up and running. As ever, Vic has thought through the challenges of shipping a fragile product, slate believe me is very easy to break in transit. Investing in flight cases for shipping is an excellent way to achieve maximal protection and at the same time avoiding expensive packaging which the owner will most likely have to dispose of. You can find a picture of the flight case at http://www.trans-fi.com/salvationmanual.htm.
    Salvation sits on a slate plinth supported by 3 adjustable large spiked legs planted on aluminium feet. The bearing mounting is set into the slate plinth, the inverted bearing features a ceramic ball acting on a Lignum Vitae thrust plate. Lignum Vitae is a magical material, not only is it incredibly dense, it’s also self lubricating. Uses for Lignum Vitae include lawn bowls (as in balls), clock mechanics, ship propeller bearings and even police truncheons. Having tried a number of thrust pad materials I can say that I found Lignum Vitae to be the best, the difference in bass performance between various materials was surprisingly easy to discern. This brings me on to an aspect of the deck I noticed from the outset; a lack of what is often mistakenly called “vinyl roar” which is typically “bearing roar”. With the stylus in an unmodulated rotating groove the lack of roar is very welcome indeed.
    There are two platter options for Salvation, there’s a 12 inch acrylic platter and a 14 inch stepped platter weighing in at 9kg. Both platters are rim-driven from a free standing motor pod. The motor pod is engaged via a lever with the driving pulley acting on a rubber traction band around the platter. The motor drive is very direct, quite unlike a belt drive deck and it’s more direct than Garrard idler drives too. The removal of lossy isolation of the motor requires an extremely well sorted drive system and an especially well developed power supply. Take it from me; it’s a cinch to hear VERY minor changes to the power supply.
    Where the rubber hits the platter:
    Vic’s goal is that sound quality is the most important aspect. If there are small consequential foibles the deck owner must get used to then so be it. The power supply has been an area where much time has been spent checking out many alternatives. An initially tempting power supply with motor that includes feedback speed control resulted in rock solid speed stability but it was let down by rumble transmitted to the platter and a strong hum from the controller. Close but no cigar.
    A simpler controller with compensation for stylus drag was trialled, whilst this was impressive in resisting pressures even from record cleaning brushes, in the final analysis the sound was spoilt by a smearing of bass notes as the power supply made micro-adjustments to the voltage driving the motor. Simple lead-acid supplies were tested with regulators to govern voltage from the discharging battery. It was soon found that mains powered regulators outperformed the battery once the regulators were suitably configured. So what we have on the production Salvation is a linear power supply with multiple cascaded regulators with some extra tweaks that proved to be very important. Cascaded regulators are used to massively filter out mains borne noise helping to ensure the deck performs well at any time of day. Mains power can vary in quality hugely so rejection of noise by the power supply is very important with such a direct drive of the platter.
    What is also important to realise is that the power supply purposely makes no attempt to control platter speed other than by supplying a constant voltage. There is no compensation for stylus drag or temperature. Speed does not vary or waiver over short timescales so piano notes for example do not wow. Speed can vary over longer timescales. It takes 10 or 15 minutes for speed to settle at the start of a listening session after which time the speed is usually exactly as it was from the previous day’s listening. Big variations in temperature can require tweaks to the speed setting. Typically I find need to adjust speed after a few days, not normally more frequently than this.
    The lack of feedback control for the power supply is a very deliberate design decision which results in improved sound quality. If you are someone who must have a deck which is instantly up to 33.33rpm at switch on and never ever varies from this then I suggest you need a direct drive deck such as a Technics SP10 or 1210. If you value sound quality and can live with making occasional speed setting tweaks then consider Salvation. This is “straight-through” analogue with no digital control or feedback mechanisms.
    Some final words on the two platter options; the 9kg platter permits the motor to spin a little faster so producing some useful extra torque. Speed is a maintained a little more consistently too as it takes a lot of force to change the speed of a 9kg platter. Any speed drift, even with the acrylic platter, is perfectly acceptable to me and I regard myself slightly on the obsessive side of sane. Vic has measured speed drift with the acrylic platter to be between 0.3% and 0.6%. The heavy aluminium platter betters 0.3%. The 0.3% figure is regarded in the industry as a standard to achieve. Direct Drives better 0.3% but many others do not. In terms of sound both platters sound great. For the aluminium platter a mat was required, we tried many mats, mats are very deck dependant so simply picking a mat you know to have worked well on another deck doesn’t mean a jot. In the end acrylic was found to be best, which is interesting and justifies why the acrylic platter also sounds great.
    In attempting to describe how Salvation sounds I will contrast it to my Garrard 301 which is mounted in a twin tier plinth armed with an Origin Live Encounter mkIII. I have also used T3Pro on the 301. First up I have to say that the 301 is a fabulous deck, I love the looks and operation. I also love the drive and power of this idler drive deck. The 301 of course has many committed followers, I hope I won’t upset too many when I say it’s not the most neutral sounding deck. Its colourations are generally very benign but they exist even with a good plinth such as mine. I’ve managed to ameliorate most of the colouration by voicing my Hagerman Cornet 2 phono stage for use with the 301. What I’ve done is to choose a combination of tubes and capacitors which result in a slightly lean bass and emphasized treble, this compensates for the tonal foibles of the 301. My 301 used in this way is a very nice deck indeed, you have to go a long way to improve on the 301 sound. As a point of reference my 301, arm and plinth would cost 2,000 to 2,500 so price-wise it’s in the same league as the Salvation. A 301 needing restoration and using a high-end plinth maker you could stretch the cost for a complete 301 deck to over 3,000.
    My Garrard 301 with Encounter mkIII arm:
    OK, down to brass tacks. The very first early development version of Salvation I received amazingly clearly out-classed my beloved 301. Particular strengths noted at this early stage of development were incredible dynamics usually associated with idlers and a precision I associate with direct drives, pretty amazing. Vic has continually developed the deck over the last year to the point where it is now in production form. As you can imagine Salvation in production form now out-classes my 301 even more considerably. Worryingly so but don’t tell anyone, I want 301 values to increase, not decrease! Just as the T3Pro is one of the world’s great arms and a hi-fi enthusiast bargain, equally so is the Salvation record deck. It’s actually quite hard to characterise a deck that simply gets the sound so right. There is no apparent character from the deck, detail and clarity are superb. Soundstage and imaging are wide and deep, the separation between instruments is excellent. Bass is thunderous when it’s there in the recording. Dynamics are however the first thing that hits you, so to speak. My London (Decca) cartridges play their part here but the deck has to allow them to shine, and it does. Recording quality is very easy to hear, poor recordings are listenable but put on a great recording, often from the 50s or 60s, and you are rewarded big-time!
    My Reference tracking on the14 inch 9kg Salvation stepped platter:
    I’m not going to do the typical reviewer thing of reeling off how various records sound, this can be so system and room dependant that I don’t feel it’s particularly useful. A comparison to my Garrard 301 is probably more useful and for sure it’s the best comparison I have as the decks are side-by-side. You maybe aware that Garrards such as my 301 are highly regarded for their dynamics, and rightly so. Salvation takes on the 301, competes and leaves the 301 trailing its wake, especially so in terms of dynamics. If you listen to my 301 you’ll think, that is a great sound. Then you move onto Salvation, you’ll be shocked at just how much better in every aspect it is. Aside from bass power, extension, timing, mid-range clarity, treble clarity, soundstage, imaging, macro and micro dynamics, Salvation simply has a depth to its sound; it makes music a more meaningful performance.
    How can I describe the Trans-Fi Salvation succinctly? It’s Alive!
    Review System Context
    Cartridges
    London Reference
    London Jubilee
    Ortofon Kontrapunkt B
    ZTX R100H
    Phono Stages
    Ray Samuels F-117 Nighthawk
    ECC83 with CCS / ECC88 with CCS, diy design
    Hagerman Cornet 2
    S&B TX-103 Step Ups
    Hagerman Piccolo
    Preamps
    Tram mk2 DHT
    S&B TX-102 Transformer Volume Control
    Power Amps
    LD91 (300B SE)
    Speakers
    Bastanis Mandala Atlas with Chrystal drivers
    Bastanis Mandala 18 inch dipole basses with XTZ Sub Amp 1 DSP amplification
    Last edited by Dalek Supreme D L; 16-01-2011 at 16:03. Reason: addition of revised material
    TT 1 Trans-Fi Salvation with magnetic bearing + Trans-Fi Terminator T3Pro + London Reference / Transfiguration Spirit III
    TT 2 Garrard 301 with NWA main bearing + OL Encounter mkIII + Ortofon 2M Mono SE
    Digital Fanless i5 Skylake ASUS H110T transport with HDPLEX LPS / Fidelizer / Foobar & Bug Head + Metrum Musette with Regen
    Preamp John Chapman's Slagleformer-based AVC-1
    Power Amp Ladyday 300B SE with gorgeous WE 300Bs alternating with EL84 SE, Quad 306 (Dada upgrade) and Temple Audio Bantam One (integrated)
    Bass Amp & DSP Behringer iNuke NU3000DSP
    Speakers 1 Bastanis Sagarmatha Duo
    Speakers 2 MarkaudioSota Viotti One
    Excellent review Clive both providing background to how the Salvation got to this point and how it sounds. It does look tempting but not sure I could find that kind of money quickly and before he ends up becoming VAT registered. Do you know if the Salvation can take a standard tonearm as a I have the other champion of enthusiast/come builder arm, Jeffs Audiomods VTA arm and suspect it would make a good pairing.
    Paul.
    I'm Clive.
    Hi Paul, thanks, glad you liked the review. Re VAT, it's only my personal comment, I've no idea what the risk is that 20% will be added.
    The deck hasn't been tested with any other arm. Vic enjoys special projects, if he's not too busy. Adapting the deck for the Rega fit & interesting Audiomods arm might be something he'd undertake.
    I'm ILOB.
    I personally would stick with the Terminator pro the deck and arm really go well together. Bare in mind this would probarly not be any cheaper and perhaps take longer but speak to Vic he loves a challenge
    Great review Clive The pictures really add to the story and you manage to get a cross just how important each item is getting the sound right.
    Like Clive I have been lucky enough to see this turntable grow but more from a distance. Each time I visited Vic it would of had another modification each modification would add more improvement
    This is a fanastic Turntable that offers crazy value for money
    John and Clive thanks for the suggestion of talking to Vic. Re VAT Vic would have to be taking 70k on this and other items sold which I think is achievable but of course is a matter for Vic on how he runs his business.
    I have a Lyra Argo i on its way this evening from a Wammer which I expect to drive me towards a better phono-stage so a Trans-Fi Salvation would be some months off if I was to go down that route.
    Paul.
    I'm ILOB.
    Paul I hope to have the SALVATION in a few weeks so you more than welcome to hear it
    John, I may well take you up on that, your a short ride away on the C11 if your location is correct. Your music tastes are even more catholic than mine... in a good way.
    Paul.
    I'm ILOB.
    Yes I have pretty wide taste but bring your own albums always best to listen to music you know Yes C11 take you to Brentx then 232 or 182
    Hi Clive,
    Fabulous review, and very well written and professional as usual!
    If I were in the market for a brand new T/T, the Salvation is the one I'd buy. It ticks all the boxes for me and I have a huge admiration for Vic as a designer.
    Sometime soon we must have another sesh, and I'll being the Techie along, where I expect it to lose royally, but it'll be fun seeing how close it gets!
    I'm also sure the experience will be educational for both of us
    http://www.thestainedglasscompany.com
    "A man is a success if he gets up in the morning and gets to bed at night, and in between he does what he wants to do" -- Milan Kundera.
    I'm ILOB.
    Marco the dynamics on it is scary. I never heard such transiant attack I hope you can hear it soon
