Results 1 to 10 of 12
Thread: Just in case you haven't seen it...
    Wink Just in case you haven't seen it...
    All HDMI cables are not equal, i guess i should have realised this when experimenting with other digital audio cables a good few years back
    Thoroughly recommended, both the G720 & the G1080 that supersedes it. Having tried a few others i have replaced, or should i say i have bought all MG cables to use in all my HDMI connections.
    Bests, Mark
    You learn something new everyday, cheers mate.
    I'm inthescottishmafia.
    Yes agreed, the MG was a definate picture improvement for me.
    Indeed Ali, the shocker though was the Belkin PF40 Quite unbelievable
    Bests, Mark
    Didn't get one of those, though have 3 PF30's. They do help.
    Same thing at the end of the day, PF40 just has a fancy display...
    Quite unreal how a mains filter can make so much difference
    Bests, Mark
    Indeed, though I guess it depends how good/bad your mains is in the first place. Regarding the cables- how much better is the 1080 than the 720?
    I'm not too sure how much better the 1080 is compared to the 720, but it is You see very shortly i'll get my system sorted as i want it & unfortunately this will result in an 8M HDMI run from an Octava HDMI switcher in my rack to the TV... There will be a 5M run from the Octava to my projector.
    As soon as i received the 8M run of 1080 cable i naturally connected it up to try it out, again there were no problems unlike other HDMI cables the didn't like to work at less than 2M with the Philips TV & Panasonic player combination
    The G1080 will allow you to work with longer cable lengths & still maintain the utmost quality & this is what i needed. No idea what the same length of cable would be like compared to the G720, logic tells me it'd be better, but whether this would result in an improved picture at the end of the day i honestly don't know
    Bests, Mark
    I'm Will.
    Quote Originally Posted by Reid Malenfant View Post
    Indeed Mark...
    Because of the industries 'enforcement' of encryption (idiots!!! there's loads of software out there anyway!!!) on an HDMI lead they are even more vulnerable to interference, as it's a bi-directional conversation.
    This is particularly noticeable on longer lengths, I use a 15' one for my projector, I eventually settled on a Chord one (white but can't remember the model), a bit expensive but worth it.
    Unlike audio, which can be subjective, with video the effect of a good or bad cable is patently obvious particularly with a projector. Just freeze the frame on a good quality disk with some sky and horizon, and have a close up look at the distortion caused by the cable...
    Cheers, Will
    In my opinion this is where high quality cable realy comes into it's own, when you need to have long runs, but it does rack the price up
    Tell me mark is there any reason why you keep your TV in a different post code area to your Bluray player
