If you are thinking what can a fuse do for my system then please think again. These fuses will give your system an instant sound quality improvement. The stock fuse fitted inside your amplifier, cd player etc, etc is a basic 9p fuse with thin wire and made in bulk, its only designed to save your equipment in the event of a power surge or malfunction.
The Hi-Fi tuning fuses are manufactured to improve your hi-fi system, that's it. Using solid silver internal fuse wire, ceramic body, silver plated end caps with gold plating over the top and finally cryo treated, I have sold enough to know that these are not gimmicks and really do work. Available to fit inside your equipment and also in a UK mains plug.
There is a test report for the fuses on my website in the downloads section under http://www.mains-cables-r-us.co.uk/downloads.html
A review is here:-http://www.6moons.com/audioreviews/net/net.html
If you are serious about your sound quality, this is the most cost effective up-grade there is.
http://www.mains-cables-r-us.co.uk/o...ade-Fuses.html
