Results 1 to 10 of 18
Thread: Modded Pioneer dvd player
    Default Modded Pioneer dvd player
    http://www.positive-feedback.com/amb...Concept414.htm
    After telling a friend about an Oracle CD1500 demo, he suggested that I should look into modding a Pioneer DVD player. He says that this modded player will be a substantial improvement over the Rotel CDP. Have any of you tried any projects such as this? Any feedback will be appreciated!
    I'm BigBobJoylove.
    Townshend certainly have as Jason Kennedy will attest to. Basically it's a Pioneer 565 DVD player modded to everything-else-high-end-demolishing specifications. Certainly worth having a crack at it.
    Ben Duncan mains conditioner
    Samsung QE75Q90T 75" QLED TV
    Atacama SE24 stands
    Welcome back! Where have you been, ya slacker?
    Thanks for the info! This unit looks killer! I hate to ask what it costs but it looks as though it would be a significant upgrade. It may take a little to upgrade the Rotel as our economy is in the toilet and the fixer-ups on this old house are overwhelming. Still I can be a very determined fellow.
    BTW, How do You insert the various smiley icons when posting?
    Cheers!
    Just click on them on the list in the reply box (including the ones available on the 'more' option, and they appear next to your text
    I'm inthescottishmafia.
    Strangely Marco,that doesn't work for me,I have to use the smiley icon that has a drop-down menu above where you write your text when posting.Perhaps you have the same problem KMair?
    That's a funny one, mate. You should be able to do both
    Can you not see the list of smilies to the right of the reply box before you post?
    hi, Im Mia, after read all the posts seems like its not the better in the market, anyone knows the price?
    Hi Mia,
    Welcome to the forum
    I'm not sure that I fully understand your last post. What is it you're trying to say?
    Yes Marco all the emoticons are there,they just don't do anything when I click on them! I have to use that drop-down menu as I described above.I thought perhaps kmair had the same problem.
