Results 1 to 3 of 3
Thread: 600ohm Headphones on a Caiman
    I'm Bryan.
    Default 600ohm Headphones on a Caiman
    Just wondering whether any of you good folks have had any experience of using high impedance headphones on your Caimans.
    I have been reading around this subject for what seems like months now, and have pretty much decided to go ahead and order a pair of Beyer DT770/600 ohm.
    I've arrived at this choice as they seem to be recommended for the genres of music I like (downtempo electronica - Massive Attack, Air and also rock, Radiohead Pink Floyd). They are closed back just to prevent annoying others
    Without being able to audition them, I can only go on other peoples impressions, and they suggest that the 600ohm models benefit from a more open soundstage, as well as fuller midrange, smoother treble and bass control, when compared to the same model with 32/250ohm impedance.
    They also qualify this by saying that they need 'good' amplification, ideally from a tube amp. This is an area I have no knowledge of, so hopefully someone can help me.
    A dedicated headphone amp is financialy not an option unfortunately. When I pluck up the confidence I will try the mod on the Caiman headphone output, but do you think the 600ohm beyers are a mistake? Should I stick with the 250ohm model?
    Thanks all for any advice and suggestions
    RP6/RB303/Exact | V-link 192 Rega DAC | Brio R | Rega RS3
    Mark Grant Supra Trico WBT 0110 Cu, Speaker Cable Tellurium Q Black, Rega Interconnect & Mains Cables
    The Caiman comes with LM4562 opamps at stock.
    http://www.national.com/pf/LM/LM4562.html
    These are high fidelity and will happily drive 600ohm loads.
    Tom
    AKG K701, TC-7520 HPA/DAC, Yamaha RX-V396RDS, Some awful speakers
    I'm Bryan.
    Thanks Tom
