Originally Posted by
jbloggs
If you are using an external HDD->USB in of Touch, seemingly it is best that the external HDD should have its own power supply and not draw it from USB port on Touch...
I have used a few DAC's with SB3 and Touch via coax and toslink (I use a small file server with SqueezeBox Server installed for storage) and it has always been straight plug and play...
I think also that the USB drive needs to be formatted FAT32, not NTFS, which is a pain.
