Please help this analogue fool embrace digitalia.
I have a Stan Dac on it's way and I want to use the coax (only) for time being. Do I need to buy a dedicated spdif coax cable, or can I use a single rca phono interconnect?
Thanks
Thanks
Nick.
Don't use a standard phono interconnect
Get yourself a decent 75ohm digital interconnect. This is kind of problematic as phono plugs have no defined impedance so tend to f*ck it up
Cable impedance is important though, if you want to go cheap but reasonable get yourself a metre or so of good quality screened satelite coax & add your own plugs
Pity you have no BNC 75ohm connectors on the device
Bests, Mark
Get one of Stan's TRC-222-1M.
Chris
Common sense isn't anymore!
Crystal.
Thanks fellas.
Nick.
