hello, im on the hunt for a Mike New platter for a technics sl1200. please let me know if anyone has one fs or knows of one available
I'm Mazen.
Technics SL-1210 MK2 | Funk Firm spin bearing | Ortofon AS-212 tonearm | Denon DL-103GL | Funk Firm APM Achromat | MCRU step 3 LPS
DYNACO VTA st-70 bi-amped | DYNACO PAS-4 preamp | EMT Haufe T-890 SUT
JBL 4325 | JBL 2397 | JBL 2402-05
Do you own the Mike New bearing? I'm not so sure that the platter will work wih your Funk Firm spin bearing. You might want to check.
If a. Ike New platter fits a standard bearing, it will work on a spin, as it has the same geometry.
Kevin
Yeah, Funk used a Mike New bearing to 'design' their one so it'll be fine. I owned the one they used
They may have used one in the design process, but AK told me the MN geometry did not match the original technics in the area the platter sits. When I had both, I never bothered to measure them to see if it was true.
Anyway, getting hold of a Mike New platter is going to be a challenge, IMHO.
Kevin
