Results 1 to 10 of 12
Thread: Ortofon Rondo Bronze MC cartridge
    I'm Ian.
    Default Ortofon Rondo Bronze MC cartridge
    This came with a tonearm I purchased and I was told by the seller it had very light use but obviously I cannot verify this. I did consider buying a step up device for my mm only phono stage but was a little shocked at the price these days!
    The cantilever is straight and the stylus looks in good order.
    Apparently the Rondo Bronze cost around £700 so I think £250 including UK mainland postage seems a fair price. I don't have original packaging but I do have packaging from another cartridge which will keep it safe.
    I'm Peter.
    hi do you no how old this is , say 14 to 16 years?
    I'm Ian.
    I'm sorry I really don't know.
    I'm inthescottishmafia.
    Nice cart, have one myself. GLWTS.
    Hunter S Thompson
    I'm Ian.
    Thanks Ali. I must admit I'm in two minds about selling this. I've seen a Denon AU-300LC step up for reasonable money and presume it's 1:10 gain will work well enough. Any opinions welcome.
    I'm malcolm.
    Quote Originally Posted by ianlenco View Post
    Output of Ortofon Rondo Bronze MC is .5mV so 1:10 will take it to 5mV - should be fine
    Audiophile Tosher
    True, but the loading impedance if used with a standard 47kOhm MM input will be 470 Ohm. This might be a little too high and cause the treble to sound a bit 'lively'.
    Try it out first, you can always reduce the effective load impedance by wiring, say, 220 Ohm resistors across the transformer input.
    I'm Paul.
    The Denon AU-300LC I heard many many years ago and not impressed... If you can find an Audio Technica AT-630 which at times are under £100 I would go there/... Good luck...
    EMT 930ST
    Garrard 301/3009 MK1
    Micro Seiki MR-711/MA-202L
    Stax SRA-3S MM phono amplifier
    Nagra BPSv2 phonostage
    BigBottle BB3 Phonostage
    Telefunken Bv.42-01 Transformer
    Hashimoto HM-3 Transformer
    Braun CC4 Transformer
    Ortofon Spu Synergy
    Ortofon Cadenza Bronze
    Miyajima Waza
    Denon 103SA
    Audio Technica AT33 Mono
    IFI Pro Linestage
    PYE HF12 KT66 Monoblocks
    Uchida Sun Audio SV-300BE
    Crimson Elektrik CS1500
    Quantum Electronics 202D
    Marantz 1060 Integrated
    Western Electric Line Transformer
    Yamaha CDR-HD1500
    Tannoy 15" Bespoke
    I'm Keith.
    You have pm
    I'm Ian.
    Thanks Paul.
    As it happens I've just bought the Denon! Main reason is to make sure the Ortofon Rondo is working properly and then maybe I'll like it enough to keep it and progress to a better SUT
