YBA A100 amplifier
Hi all.
Selling my Yba amplifier that I have owned since new.
Comes with original box which has the wooden side panels used to strengthen it.
Original remote with remote box.
Manual and letter regarding operation of the volume.
I will supply a new after market mains lead.
It is 1.5m
My price is £650 which includes tracked 24 hour courier within the UK mainland.via tracked insured courier within the UK.
Payment is best via PayPal but bank transfer is fine transfer is fine if you do not use PayPal
Here is what yba say of the amplifier.
YBA
HERITAGE A100 INTEGRATED AMPLIFIER
The A100 from YBA shows a great maturity and will combine with ease with many types of source products and loudspeakers. as its power seems without limits. Its flexibility is equal only to that of its musicality and it becomes an essential choice for all those who seek above all, an amplifier combining refinement sound and speed.
Description
Additional information
Reviews & Documentation
All products in the Heritage range utilise the same stylish chassis in brushed aluminium that can be obtained in two different finishes, silver or black.
The chassis rests on three feet, two of which are damped, the third in aluminium ends in a metal ball serving as the vanishing point of the vibrations. The power on/off switch is located on the underside of the chassis towards the front of the left hand side. Two buttons feature on the front panel, one for source selection and one for volume and centred between them is an oval-shaped display with yellow lettering indicating the connected source and the volume reached. A beautiful remote control will allow you to access the functions from a distance.
The A100 has 5 sets of RCA inputs and 1 balanced. The video input has a by-pass feature (by-passing the preamplifier section). It also has a pre-out should you wish to use a separate power amplifier, a pair of powered speakers or to connect a subwoofer. It has one pair of speaker outputs.
Product type
Integrated Amplifier
Audio outputs
1 pair of speaker outputs,
1 pre-out (RCA)
Power output
100W @ 8 Ω per channel
150W @ 4 Ω per channel
SNR
> 95dB
Frequency Response
20Hz-20kHz (-0.5dB)
THD+N
< 0.04%
Inputs
5 RCA, 1 balanced
Power Supply
Linear power supply with high performance
transformer 320 VA
Color / Finish
Black, Silver
Dimensions (w x d x h)
430 x 400 x 118 mm
Weight
9.2 kg
Hifi choice review
https://www.hifichoice.com/content/y...tage-cd100a100
Click on pictures to view them in full.
IMG_20240314_122543167~2 by Jason Croft, on Flickr
IMG_20240314_122626580~2 by Jason Croft, on Flickr
IMG_20240314_135119998~2 by Jason Croft, on Flickr
IMG_20240314_122616552~2 by Jason Croft, on Flickr
IMG_20240314_133430197~2 by Jason Croft, on Flickr
IMG_20240314_122526855~3 by Jason Croft, on Flick
IMG_20240314_122653785~3 by Jason Croft, on Flickr
IMG_20240314_122746424 by Jason Croft, on Flickr
IMG_20240314_135307862~2 by Jason Croft, on Flickr
IMG_20240314_122837073 by Jason Croft, on Flickr
IMG_20240314_122847614 by Jason Croft, on Flickr
IMG_20240314_122551788~2 by Jason Croft, on Flickr
IMG_20240314_122547758~2 by Jason Croft, on Flickr
IMG_20240314_122842528 by Jason Croft, on Flickr
IMG_20240314_122754508 by Jason Croft, on Flickr
- You may not post replies
- You may not edit your posts
Forum Rules
