Hello guys. I'm looking for recommendations for a reasonably priced USB microscope with software to measure and set SRA.
Thanks
Andy
Thanks
Andy
Tony who runs PinkfishMedia knows about scopes for stylus use, if you're on there he might be able to advise.
Cheers Mikey.
these are very good. i use mine to check when sharpening..
https://www.amazon.co.uk/dp/B09Q65J3...roduct_details
Was looking for a pic or 2,..
Took this. The second is a knife edge which is slightly magged. It's both wired to pc or wireless to phone etc
Wireless is good. The stand is solid but extra
I have one of these which I no longer have a use for:
https://www.amazon.co.uk/Microscope-...strial&sr=1-70
If you can make use of it, it's yours.
Send me a PM if interested.
