I would personally class a TT bearing as a slow moving part, even at 78 RPM.
Kevin
After much deliberation I have decided to use oil on my turntable bearing as it sits in a brass oil bath bearing and really this is the most suitable lubricant and recommended by users and owners across the internet. I think grease would be too thick and as the bearing has so close a tolerance it would only need a very small amount of lubrication anyway.
Tomorrow I have cleared the day for the operation but will also clean and calibrate the turntable at the same time ensuring nothing is loose or defective. It has been about 3 years since I last did anything with it so its about time!
SAE 30 synthetic compressor oil is a favourite of mine, especially for oilite bearings.
Audiophile Tosher
I did a little maintaince on the 301! It's amazing how fast goes by. Keep us updated with findings.
I have used this on a couple of turntables and it works very well, you could add a little to some low friction SAE30 or similar. They use this stuff in racing engines.
https://www.team-zx1.com/extralube-z...treatment.html
Oils are definitely a science and technology in themselves. So many specialist products out there and applications. I have a range of oils and different types of grease I use on my bike and they are all manufactured in handmade batches with a secret set of ingredients? I know a fair bit of the technology is to use very low friction materials but also there are some that are used for waterproofing and making the oil viscosity such that it sticks to stuff with our being flung off.
I imagine car engine oils are as much about operating in various extreme heat environments as well as friction functionality. So when you look at many of the oils out there and start to go into detail you find there are many technical aspects of the oil that are not needed in a turntable bearing. In fact I would say they actually need to be fairly simple compared to the extreme applications found in automotive and other engineering applications?
I'm Paul.
Still do and always have used fine sewing machine oil, which has never clogged up on any of my turntables.
HI-FI SYSTEM:-
Revox B250 Amp.
Revox PR 99 mk2 R2R.
Revox B126 C/D Player.
Yamaha GT2000 T/Table with Shure MKIV Cartridge and Jeco VN-45HE SAS/R Stylus.
Bang & Olufsen Beolab18's and the 19 Sub Speakers.
A/V 5.1 System :-
Soundsend Wisa box.
Harmen Kardon front and rear satellite.
Legend 10.2 Silverback Active Centre.
Yes I agree on that with respect to specialist applications. I have fount the ZX1 makes a significant difference in friction reduction on several TTs, and presumably noise as a result. I tested before and after by timing how long it took the platter to comet to rest from 33rpm and 45 rpm, and it was over twice as long to come to rest with the ZX1, so certainly made a difference. You only meed very small quantities so a small bottle of 5ml or 100ml is more than enough.
