Results 1 to 10 of 16
Thread: PCM player advice
    I'm martin.
    Default PCM player advice
    Apologies for a stupid question - I'm mainly an analogue listener.
    I've recorded some of my LPs onto a 24bit 92khz audio recorder in the PCM WAV format and was wondering if the playback would be improved if played on something else rather than the Mac laptop.
    I don't have a digital out on my audio recorder.
    I'd output from the laptop via USB to an external DAC that should give you 100%.
    I'm martin.
    Thanks. How much would a DAC better than the Macbook built-in one cost? Which one would you recommend for a noticeable improvement?
    Get one of the Topping or SMSL DACs for about £100 they are decent for the money.
    Quote Originally Posted by martinswimmer View Post
    It's not so much that it will be a better DAC just that having it off board eliminates the possibility of added noise.
    Like Lawrence says a DAC from Topping or SMSL will be notionally perfect and not expensive.
    A separate DAC used with a MacBook is noticeably better but you don't have to spend too much cash. I have had a number of MacBooks and use Audirvana and my off board DACs have always sounded better.
    I'm Martyn.
    S.M.S.L SU-1 has had many positive reviews and is a very sensible cost
    https://amzn.eu/d/hKzoImZ
    Sent from my moto g32 using Tapatalk
    "Notionally perfect". What a can of worms you have summed up so elegantly
    is it possible to sum up a can of worms?
    Must be if you did it
