Guidance on noisy channel on Topping D30 DAC
My Topping D30 DAC has a burbling type sound on one channel
Info
1. It increases in volume if the amp is turned up.
2. Swapping DAC to amp cables (L to R) makes no difference
3. If the digital source is turned off the DAC is deathly quiet but the noise comes back as soon as the source is turned on and the DAC has to perform.
4. The digital cable between source and DAC has been substituted without changing anything
5. Aside from the noise, the DAC is performing admirably.
6. I have taken the DAC apart and wiggled and tapped every component without change (it is only 5volts!)
6. It is not a mains hum.
Any ideas, or should I just chuck it out
Cheers Chris
Source
SW1X USB II
SW1X DAC III Special
Audiolab 6000 CDT transport
Amps
Speakers
BK Electronics XLS400FF Sub.
Cabling
Headphones
