Results 1 to 6 of 6
Thread: Skyq to TV to soundbar
    Default Skyq to TV to soundbar
    Morning all, I've just hooked my new soundbar, denon dhts 517. Connections are hdmi from skyq to TV, arc from TV to soundbar, all good so far. Now to setting, skyq set to Dolby digital plus ,to take advantage of atmos content, if there is any? TV set to bypass, does this sound right? Ta
    unfortunately i dont know but trial and error should show the path
    I'm sticking with the set up as per my first post Grant, setting tv to dolby digital plus throws up lip sync issues . At a guess the TV is processing the audio again before it gets to the soundbar. Anyway all done thanks. The voice enhancing mode is a delight for my slightly dodgy lugs
    might be a delay setting to get them synced
    My TV has a delay function in the sound menu for when you fit an external speaker or processor it works a treat.
    Sent from my PCT-L29 using Tapatalk
    Yes there is,on TV and sky box, what a pain getting that right! Using a news channel , easy to see people speak I got it almost but not quite right,change channel and it's out of sync again, using bypass just works .needn't have bothered posting really
