I'm Shaun.
Source
SW1X USB II
SW1X DAC III Special
Audiolab 6000 CDT transport
Amps
Speakers
BK Electronics XLS400FF Sub.
Cabling
Headphones
I'm Shaun.
I did use a Cambridge transport and Audiolab MDAC but this unit is now way better than the old ones. This one is also SACD of course and I own quite a few of those.
I'm Shaun.
But as long as they are close enough to both be enjoyable that's the main thing.
I find myself happily using either format - vinyl about 40% of the time, and CD when I'm feeling lazy/pissed/whatever which makes up the remaining 60%. I do actually prefer the sound of my vinyl rig, but at fifteen times the cost of the CD player I bloody well should do. And that's before you factor in the cost of stylus wear and vinyl purchases.
I wouldn't mind changing the player at some point, and yours and Martin's players would be top of my list, but I'm in no great rush
I'm Shaun.
No wonder at all Martin. Although vinyl prices have probably only increased over the years roughly in line with inflation (My first album, T. Rex Electric Warrior cost me £2.30 iirc, which would be about £30 in today's money), it's the lower cost of CDs that makes it look bad.
Regarding the hardware, well you can see better with a turntable where much of the cost has gone, that engineering won't come cheap.
My only real gripe is the quality of the vinyl itself, which with modern pressings is unpredictable at best. And that will probably put an end to my record purchasing. Especially when a used CD version can be had for a tenth the cost, and with zero issues pretty much guaranteed.
As for streaming, not going to happen as long as I can make the journey between my sofa and the stereo
I'm Shaun.
My apologies Dave, er Rodney, er Shaun
New bloke at the builders merchants used to call me Stuart. It went on for so long I didn't have the heart to correct him as he was what they used to call "Care in the Community" and I didn't want to mess with his head. So I became Stuart. No biggie, I've been called worse.
