I'm Paul.
Here's the 15 ohm LS3/5a https://dougbradyhifi.com/products/r...ls3-5a-classic
£2.8K - obviously clean SPL will be limited with an 8 watt amp as hardly the most sensitive speaker, with subwoofers and a high pass filter it might work okay.
Leak Sandwich are 15 ohm and not expensive although they're not that great IMO.
I think some old Goodman's models were 15 ohm? Geoff might know.
Anything pre about 1968 may well be and Celestion and Wharfedale too.
As to the question of using a 16 ohm matched amplifier, it may well drive 8 ohm speakers that are an easy load perfectly well. If it doesn't like a particular speaker, it may make 'rude noises', but is unlikely to be damaged, unlike a transistor amp. I'd certainly try it myself.
Do a bit of Googling, you'll see what I'm saying, impedance mismatches with valve amplifiers are generally not a big deal. I'd avoid OTL types though.
You never know how things may work out. My vintage KEFs are only about 83db/watt sensitivity, but my 4 watt Class A valve amp drives them to useful levels in my small listening room, with enough output to suggest the setup would be OK in a roomier environment.
