Results 1 to 10 of 13
Thread: Tannoy Monitor Gold 12RS - Full Restoration & New Balmoral Style Cabinet Build
    I'm Gerard.
    Default Tannoy Monitor Gold 12RS - Full Restoration & New Balmoral Style Cabinet Build
    In early June, I made the decision to have my Tannoy Monitor Gold 12RS fully restored and new cabinets built.
    I purchased the Golds around 10 years ago along with the original crossovers, strangely only one of the crossovers had been worked on previously (a re-cap and the other was untouched).
    Cosmetically, the driver’s had the usual doping stains - in addition ‘teenagers’ had applied greasy stains whilst partying several years ago – the drivers really didn’t look good!
    I contacted Frank (@cooky) re the work and sent him pictures of the state the drivers were in.
    The teenagers handy work was giving Frank cause for concern; however, we needn’t have worried . . .
    I drove over to Frank’s place with the drivers, discussed the options and decided on the following work:
    • Drivers - clean up and cone surface refurbishment.
    • Crossovers – we decided against new crossovers and to recap the originals where necessary.
    • Terminals: Swap for new binding posts.
    • Cables: Purchase and fit Gold plated ‘new build’ 4 Pin Tannoy speaker plugs with new wires.
    I contacted Fraser (@fraserking) a cabinet maker and long-time friend of Frank’s to ask if he would consider building some new cabinets and Frank made a start on the drivers . . .
    First up, the cones and dust caps were coloured. The rubber surrounds were cleaned, and rubber restorer applied. When cleaning the rubber an incredible amount of tobacco stain came off – these obviously belonged to a heavy smoker in the past.
    Frank needn’t have worried the results he obtained were excellent, and the drivers were now looking great, Night & Day:
    Next up the crossovers, Frank found capacitor mismatches, here’s a picture of opened crossovers before re-cap.
    So new Clarity cap ESA were fitted for HF, and to preserve the use of electrolytics Alcaps were fitted to the bass section.
    New Jantzen speaker terminals were fitted to replace the poor-quality original binding posts. The diagonal corners of crossover bodies were secured with Allen bolts, 2 brass bushes transferred from other crossover so they matched and new velvet applied to bases. New crossover cable with gold plated Tannoy 4 pin plug fitted. New crossover cable with gold plated Tannoy 4 pin plug fitted.
    The existing gaskets did not look good and were too tall.
    New gaskets were needed, Tannoy ones are no longer available, and regardless a lower profile was sought for any new replacement. In addition, the existing clamp screws protruded quite high, and any new arrangement needed to deal with this. Frank’s solution was to build a new thinner gasket out of two layers of 3mm gasket. To stop the clamp screws causing any bumps in the top face of this thinner gasket cuts were made in the underside of the lower layer.
    The new completed gasket, in this photo you clearly see the work Frank has done restoring the rubber of the surround on the 12" Gold RS.
    The HF drivers were stripped, cleaned, and re-aligned.
    All tested and good frequency match found for Tanoy’s – ignore response below 1kHz, drivers in free air.
    Great work by Frank and all now ready for Fraser King . . .
    I'm Gerard.
    My existing cabinets were based on the dimensions of Chatsworth cabinet (volume 83 Litres), I was looking forward for something taller, more wife friendly and with grills.
    After discussing the options with Fraser King, we decided on the following for the build:
    Balmoral Style Cabinets
    Size (Excluding Plinth) = 98cm High x 42cm Wide x 38cm Deep
    Plinth = 35mm High
    Material = Walnut MDF with Osmo finish
    Ply internal carcass
    Ply internal Bracing
    Cabinets lined with dead sheet and new internal foam
    Recessed Port - Black
    Grill Cloth - Speckled Grey
    Circular Tannoy Badges
    I drew up some plans
    Fraser set to work and regularly sent pictures as the build proceeded:
    First Fraser visited the timber yard to ensure the Walnut MDF had a decent grain suitable for the project.
    Osmo oil applied
    Previewing the Speckled Grey grill cloth with an earlier prototype Tannoy Badge
    Foam and dead sheet going in
    It's worth mentioning that when we were designing/specifying the cabinets Fraser couldn't find any ports 'off the shelf' anywhere that weren't either cheap looking
    or ridiculously enormous e.g. 100mm internal pipe with a massive flare of 150mm that was going to dominate the baffle and just look so wrong.
    So what did we do? Fraser made hand made ports that are more or less the same size as the dust caps and I think he absolutely nailed it aesthetically.
    Fraser had Tannoy badges made at an engravers, and I decided not to have the logo painted.
    MDF front grill with cuts out for driver and port and drilled for pegs.
    I'm Gerard.
    Fraser drove up to Frank’s place with the completed cabinets for installation of the drivers, testing, port tuning, glue backs in cabinets, listening etc.
    The following day I drove over to Frank’s to meet Fraser and collect the speakers.
    The speakers looked fantastic, we went on to have a good old listening session and they sounded bloody gorgeous.
    Later that day, the speakers were in place in their new home.
    I’d like to thank Frank and Fraser for the great skill, care, and attention to detail shown when restoring and building my new speakers.
    Thanks Lads, all the best.
    Gerard
    I'm Lloyd.
    Great thread very inspirational
    A widower finding solace in music
    I'm Gerard.
    Cheers!
    We all but a lot of effort into getting everything perfect.
    I'm Adrian.
    They look great Gerard a credit to you all, I bet they sound good too.
    proper job...
    I'm Andy.
    Top job Ged, although nothing more than I would expect from Frank, he certainly knows his stuff and is an absolute credit to our hobby. ( he rebuilt my 15" K series drivers about 4 years ago and I am still delighted with the results)
    Analogue
    401 / PU7 / AT33ev
    Digital
    Innuos Zen Mini Mk 3
    Topping D50s
    Caiman Seg & Dorado
    Cambridge CXC
    Amps
    Tron Seven Linestage
    Speakers
    Tannoy GRF Memory.
    Tannoy ST100.
    I'm Gerard.
    Quote Originally Posted by Andy831 View Post
    Thanks Andy
    Good to hear from you, how's it going?
    I'm delighted with the work Frank & Fraser both did for me! As you say they are credit to the hobby.
    Cheers
    Ged
    I'm Gerard.
    Thanks, and yes they sound great!
