Results 11 to 20 of 35
Thread: Tannoy SR840 Amp…questions
    I'm Jesper.
    I’d love to attach photos- but don’t know how to- it seems
    I'm Jesper.
    I'm Jesper.
    [IMG] [/IMG]
    I'm Jesper.
    Jubiii ��
    Fist image is the “Tube sockets”
    Second image is the whole amp, where they are located in the top right corner
    I'm Jesper.
    Back to the question/potential problem…I haven’t found any information on this & as mentioned it doesn’t look like an amateur job either
    valve rectifiers?
    I was going to ask if the sockets were 'octal'. That they are suggests they are for plug in transformers, to convert the XLR inputs to balanced type.
    I can't see from the photo if the additional sockets are located close to the inputs. Can you say if the screened cables connecting the 'octal' bases also connect to the XLRs?
    If you type Tannoy SR840 into a search engine there are a few hits which show photos and the promotional literature for the amp, as well as reviews.
    The additional octal sockets are positioned near the front of the amplifier, so you need to see if they connect to the XLR sockets at the rear.
    I'm Jesper.
    The sockets are close to the front
    Orientation of the picture is:
    top(of the pic) = front
    bottom = the back of the amp (XLR’s and all)
    And unfortunately I have no idea if the cable is screened ore connected straight to the XLR’s, as they are tucked away nicely
    This stock photo shows an empty space where the sockets are on yours so looks like it is an after-market addition.
    Not sure it's a good idea to have a valve bang up against that reservoir cap.
