Results 1 to 10 of 12
Thread: Amplifier servicing East Sussex/Kent
    I'm Loz.
    Default Amplifier servicing East Sussex/Kent
    Does anyone know a reputable person in the south east for amplifier servicing? I’d usually go up to The Midlands to see Angus or Alan but can’t get up there for the moment. Any pointers greatly appreciated.
    Cheers
    Loz
    JS Audio might be in your neck of the woods, but depends on quality of your amp and how much you are willing to spend on it I suppose. He (John Samson) does a lot of upgrades too.
    I'm Loz.
    Thanks Steve
    I'll keep that one in mind but I'm trying to avoid going into London if I can. The amplifier (Sony TA-F770ES) has a minor issue whereby the auxiliary source 'fizzles' out on the left channel now and again and returns when I switch between sources. Not a major problem but something that irritating so would like to look into it
    Have you tried some Servisol or Deoxit on the selector switch? Assuming it's a knob.
    Does sound like it might be something and nothing. Might be worth a phone chat with Alan, who may well suggest the same as Lawrence.
    I looked online and saw it had push buttons so thought it can't be this. But then I found the below and realised it still could be. You need to get to the motorised selector to clean it, they usually have a little hole that you can put the thin spray tube in, but some are sealed (eg the Arcam Delta 290/Alpha 9 that has a common selector noise problem).
    " Instead of opting for pure CMOS-switching for input selection, Sony uses the logic to control a high-quality motorised selector that’s mounted hard up against the rear panel. "
    https://yaegeraudio.com/reviews/sony-ta-f770es/
    I'm Tony.
    My suggestion would be Brett H in Lewes
    Hear Audio
    Coherent Systems
    Real high end sound with musicality not hifi
    I'm jamie.
    hi,
    this guy fixed my sony 700es when it went bang.
    https://www.vintagetech.co.uk/
    I'm Loz.
    Thanks for all the suggestions so far folks. Hear Audio are fully booked for the time being. Vintagetech looks a good shout although it's a two hour drive from me (getting around Sussex and Kent is a slow process). I'll get in touch nonetheless. I'm not inclined to open the hood myself. My skills lie elsewhere.
    I'm Don.
    I recommend David Coe....AD audio. I know he's in Wimbledon, but a nice train ride will work for you?
    Reasonable rates, and very reliable.
    Sent from my LE2123 using Tapatalk
