Which is the better connection for audio, optical or coaxial?
Coaxial
And how much do you need to spend on a coaxial cable to get better resulta?
Better than what, optical? I've found you can chuck in a single good quality screened analogue RCA and get good results if you've got a spare one.
Some will say it's the wrong impedance and you'll get reflections or something but apparently RCA itself is the wrong impedance and you need a BNC socket I've no idea why that is.
If you've got BNC rather than RCA on your dac ignore the above and get a MarK Grant G1000HD I think it is, the copper coloured one, very good value.
RCA phono connectors were chosen by Sony and Philips for the digital interface, not because they have a 75 Ohm impedance (they don't; in fact they cannot have an impedance greater than ~ 57 Ohm, and usually the impedance will be 30 - 40 Ohm), but because they are electrically short, which means that any impednce mismatches which would give rise to reflections, tend to be self cancelling.
if its well made, connection wise you'll be fine imo... same goes with optical. the ends are more important, especially with optical
Optical has limited bandwidth.
Coaxial has greater bandwidth so supports high resolution 24bit if that's your thing.
think optical can now do 24/192 max.. depends on the dac tbh too.. coax can go higher but it is grounded and hence if you have hum issues you might be better with optical. usb again is different and can be better as its timing is not done til it hits dac; again its all about implementation... best choice is dependent on your needs and system. generally unless your golden eared or need a particular rate, or your system requires a type your likely not to notice
One thing I did notice recently was choice of cable quality certainly does make a difference. I have had USB and Coax and optical cables that caused issues in my system with drop outs and poor connection so a decent quality cable is certainly a good investment.
As to cables actually sounding different in digital systems I am not so sure? From my experience there are marginal gains here.
