Having looked at room acoustics and relation to speaker interaction these are my thoughts Kevin for what they are worth.
There is a move to assessing a listening environment in order to try and get a flat frequency response which is driven by the use predominantly of Room EQ Wizard which is available to download for free. Hifi pundits and some manufacturers like to use it as a tool to look at the frequency response of a given system in a room and adjust equipment or the room accordingly either through room treatment or DSP.
I have heard the effects of both and room treatment would be my much preferred way to go as any system I have heard which has DSP applied to it sounds terrible. Basically it retunes your speakers and limits or boosts their performance to compensate for the room but from what I have heard it makes you wonder why you would bother buying a pair of speakers based on the sound or performance when DSP can trample all over them. Room treatment just controls the room characteristics and not the system which in my book sounds way better as I have heard the results.
RW will tell you what the frequency response is in your room and has been suggested as a tool for speakers placement or addition of room acoustic treatment but it depends where you put the microphone in the room and then what did you do if it even requires you to move either your chair or speakers or both into a position which is domestically entirely unsuitable. I believe when using Mini DSP device however part of the calibration process does mean it takes measurements of you room from lots of positions using their microphone.
Personally and I have spoken to others about this, I would adjust your system according to what sounds best to you and not bother measuring it. But if you do go down this route and you want to flatten the response I would suggest room treatment and speaker placement rather than DSP. And if you really want to EQ the system to sound better (flatter response) in the room I would maybe consider analogue EQ rather than DSP.
Reason: Correction
