Results 1 to 9 of 9
Thread: EUVL's (XEN Audio) Super Linear Headphone amp born
    I'm Greg.
    Default EUVL's (XEN Audio) Super Linear Headphone amp born
    Hi I finally finished my N-th class A phone amp.
    Welcome (Pioneer) Super Linear Headphone Amp designed bu EUVL (from diyaudio.com).
    Partick has a number very good mainly headphone amps to his name.
    This one is based on an old idea from Pioneer.
    This was my first extensively SMD (surface mount devices) project. I have learned a lot, the next one will be easier.
    PS As you can see it still need a proper volume control knob!
    I'm Greg.
    Wanted to add more pics, but it does not allow me anymore.
    Have I exceeded the max allowed size somewhere, it would not even do rescaled pictures anymore
    Hi Greg,
    I'll pas on your problem to the other Moderators who may be able to help. It might be due to you needing to clear out your cache.
    Anyway for the time being, I'll enlarge the photos you have posted:
    Nice work BTW.
    there is a limit on size of pic you can import into system using the site as host.
    I'm Greg.
    Do you mean I have exceeded my limit?
    Are links to externally hosted images required then? But then if these die there will be a broken link?
    Quote Originally Posted by Gregje View Post
    you do get limits so you may have yes. most folk tbh use a hosting site or tapatalk. i use tapatalk a lot, but from pc only you need a host site like flikr, imageshack etc.. there are still some free ones. ive used imageshack for many years..
    I'm Greg.
    Nice work Gregje - well done!
    I'm Greg.
    Thanks Barry for your comment and attaching the photos.
    Probably the best head amp I own.
