Page 7 of 7 FirstFirst ... 567
Results 61 to 68 of 68
Thread: Do cables make a difference?
  1. #61
    Quote Originally Posted by Wakefield Turntables View Post
    Black and decker was good enough for Peter Walker
    When Peter Walker was asked what makes a good speaker cable, he replied "Firstly: the cable should be long enough to reach between the amplifier and the speaker. Secondly: the colour of the insulation should match the colour of the carpet over which it runs." (Or words to that effect.)
    Hope the Flymo fanboys don't read this, it'll be all-out war
    They already know that if you replace the stock cable on your lawnmower with an expensive lawnophile one it gives a better cut.
    That's how Peter Walker was able to pick up the orange cable cheap. One of their cast-offs.
    Must admit despite my scepticism I do use fairly expensive interconnects and speaker cable. But I would not recommend spending much money on cables to anyone. Worth it if you can to spend a bit more than the minimum to get something with durable constriction that prevents fall-apart. (I've got lots of broken cables). Otherwise budget should go on speakers and room where there is no doubt as to the benefits.
  3. #63
    Brilliant!
  4. #64
    Wise words.
  5. #65
    I found my electric lawn mower cuts the grass better, now I have replaced the mains cable with audiophile cable costing £500 a metre.
    I hope you de-gaussed the fuse first and got it the correct way round.
  6. #66
    no need now as they are infused with vitamin d...
    I'm Kevin.
    I don’t want my cables constricted.
    You don’t “need” boutique cables. Good quality will do.
    Kevin
  8. #68
    True. Common sense should tell us when something is taking-the-piss expensive. More money spent on boutique cables leaves less cash for records/CDs, and just encourages listening to the system instead of the music.
