Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Amplifier upgrade recommendations please
    I'm Adrian.
    Well one idea to het to the bottom of the is it the pre-amp or not is to replace it with a simple passive pre-amp and try it out. I used house a Tisbury passive preamp, used with a Meridian 557 power am and it was very good, basically what came from source went into the power amp. The CD should be putting out around 1V DC so enough to feed the power amp.
    See https://www.tisburyaudio.co.uk/mini-...e-preamplifier not expensive and some times can be sourced used, easy to sell on.
    Pre-amps can/do have a sound signature of their own and unless neutral can have a detrimental effect on the end result through the power amp they are feeding.
    I'm Peter.
    Thanks Adrian, I will think about that.
    TT: Pro-ject 1.2, Ortofon Blue
    Phono stage: Muffsy
    Cd: Linn Karik
    Dac: Denafrips Ares II
    Amps: Pre: EleKit TU-8500, Power: Cambridge Audio Azur 651W
    Speakers: Chario Hiper Tower 2000
    Cables: Linn, Straight Wire & Chord Clearways
    Headphones:PC, Ifi Zen Air, Sennheiser HD450 & HD569
    I'm Peter.
    I have decided to upgrade the capacitors in the preamp, then get replacement opamps and then replace the valves, only problem with this is that the capacitors are Back-ordered
    Phono stage: Muffsy
    Cd: Linn Karik
    I'm Peter.
    Ordered capacitors and opamps, will be a christmas present, so something to do over the holidays
    Phono stage: Muffsy
    Cd: Linn Karik
