Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 96
Thread: Quantum Science fuses.
  1. #41
    I'm phil.
    Something I want to look into after some advise on where to start with fuses, amp gryphon, Sacd bel canto.
    Modded td160 super Thorens ol encounter arm hana sl cart, angle audio studio pro mc virtual battery phono amp with separate psi, Onix pre and mono amps, Onix CD player, Onix BWD and soap tuner. B&W dm2 speakers or super pencil 12 speakers, atlas cables, seperate mains power supply with earth spike.
  2. #42
    I'm Kevin.
    Improvement is repeatable and easily demonstrated, its a genuine THING - but again system dependent.
    If it was repeatable and easily demonstrated, would it not work on any system?
    What are the reasons why it would not work?
    Kevin
  3. #43
    I'm Dennis.
    How is the neutral connected to earth?
    With a very thick metal block on the consumer unit.
  4. #44
    Sounds like you have a TN-C-S arrangement.
    https://electricalapprentice.co.uk/a...g-and-bonding/
    Lots of FUD flying around from folks that's never actually tried them...
    Seems to be the way, is what it is.
    After I had my hardwired balanced mains unit installed years back,
    any thoughts pointing to "its just electricity, whats the beef?" rapidly dissolved.
    Hence my (as it turns out happy) experimentation with better fuses.
    My take?
    They work, brilliantly,
    but its system (not ear/brain interface) dependent.
    Defo worth a subjective punt in your own system?
    Price of entry is 50 quid on a Hifi Tuning Supreme 3 13A fuse.
    In my experience, I wouldn't go any lower.
    Too spicy?
    Stay with the Bussmans and be happy.
    Buy more music instead.
    If you have a balanced mains supply (presumably by using a 1:1 transformer with a centre tapped secondary), you have two 'live' or phase lines feeding your gear. Therefore the balanced secondary need to protected by two fuses, or a ganged RCB.
    Therefore the minimum cost of entry is £100. And unless the fuses are marked and conform to BS1362, and a fault occurs which damages your gear, your household contents insurance will be invalid.
    I'm Gary.
    Off top of my head:
    System not transparent enough to show difference?
    Bigger issues in system than dirty mains?
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
  7. #47
    I'm Gary.
    My BMU has dual pole RCBO's fitted on Primary and secondaries, so safety and regs wise, all good.
    I wouldn't recommend anything else with a balanced setup, especially not "normal" fuses.
    Not sure it works that way anyway.
    But for a normal 13A mains fuse, on a distribution block for example,
    You'd only need 1 fuse.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
  8. #48
    Fair enough, but my comments concerning possible household contents insurance still apply. Insurance companies will do anything to limit any claim, and if a fire was caused and any fuse in your system did not conform to BS1362, I wouldn't be surprised if they rejected the claim.
    I'm Kevin.
    Oh, that old chestnut.
    I think my system is pretty "transparent", but I don't feel the need to try a directional fuse in an AC mains supply.
    The blurb says it is directional, so it is only better 50% of the time?
    (The real reason is I can't use mains plugs fuses, as they don't fit).
    As for equipment fuses, I am not sure, I am still undecided if I spend the money on fuses, or a Benchmark preamp to drive my Mod 686.
    Kevin
  10. #50
    The same argument applies to "directional cables", especially speaker cables. (However so-called semi-balanced signal cables are directional.)
