Results 1 to 6 of 6
Thread: Pop up ads?
    I'm Pete.
    Default Pop up ads?
    Is there anyway of limiting the amount of pop up ads on the forum?
    I normally use my iPad and the amount of them is really annoying.
    Every time l touch the screen an ad slowly rises from the bottom of the screen,l remove it, touch the screen again and it slowly rises up. Then there’s the ad you have to cancel every time l click on a post.
    Drives me nuts. It doesn’t seem to happen that much on other sites.
    Any ideas anyone?
    Pete.
    Main amp is an Electrocompaniat eci2 Sony qs930 cd, Sony tuner,Stan dac,modified x10d with little pinkie se and of course Quad esl57s fully serviced with much better legs and widgets. Sometimes swap to my kef reference 3s or Rogers pro9 Tls.
    Use an adblocker?
    If I recall, subscribed members don't get ads. Also, some web-browsers like Maxthon that I use automatically block adverts.
    I'm Pete.
    Use an adblocker?
    I think l am subscribed, not sure. I’ll look into ad blockers. It just seems so much worse on Aos.
    Thanks.
    Pete.
    Quote Originally Posted by phoenixpete View Post
    Thanks.
    i dont know if you can subscribe currently as marco is still absent.. there is a list there so you can see if your on it if you want.
    top of page...contribution actions etc
    Thanks.
    I think you probably won't be, Pete, there is no "AoS Supporter" badge next to your avatar.
    I'm Pete.
    Ah right. Bum.��
    Pete.
