Results 1 to 8 of 8
Thread: Wisdom needed on amp design and theory...
    Default Wisdom needed on amp design and theory...
    There has been a long-standing and often-repeated conventional wisdom over on Head-fi, the audiophile headphone forum, that all dedicated headphone amps are almost automatically superior to the headphone sections of all receivers and integrated amps, because sometime in the 80s, manufacturers stopped using the main amps, stepped down through a nest of resistors, to power headphone sections and went, instead, to cheap op-amp based headphone sections that were, more often than not, stuck in as an afterthought.
    There has been some dissension in the ranks lately as a few newbies have bought headphone amps and reported back that they, in fact, didn't sound better than the headphone jacks on their regular hifi equipment and they felt they had wasted their money. Recently a member did the research to test the conventional wisdom. He wrote to Denon, Yamaha, NAD, Cambridge Audio, Onkyo, Marantz, Harmon Kardon, and Pioneer. He has heard back from all but Onkyo. Every one of them say their headphone sections are powered by the main amps, stepped down through a nest of resistors.
    Ooops. Conventional wisdom = myth.
    Now, of course, the true believers are flooding into the mythology gap to find other reasons why their investments in $400 headphone amps yielded dramatically different results than simply plugging into their $500 integrated amp. The argument now seems to be that headphones and speakers have very different requirements because they present very different loads, and that an amp designed for speakers isn't appropriate for cans.
    That's completely possible, I suppose. But it could also be that the difference between a great-sounding headphone amp and an average-sounding receiver is much more mundane -- the elegance and simplicity of design; the quality of components and execution.
    Can anyone help me here? Does a 300 ohm headphone need a fundamentally different amp design than an 8 ohm set of speakers? If the theoretical quality was equal, would stepping a speaker amp's output down through a nest of resistors cause those headphones to sound and behave differently than they would when being driven by a headphone amp that only puts out milliwatts in the first place?
    I'd really like to know, because I listen through cans a lot and a headphone amp is one of the items on my list of wants. But if I can get similar results from the headphone jack of a Yaqin or Glow, or even a NAD, it sure would be a more effective use of the money.
    Tim
    I'm Rob.
    Interesting subject.
    I think much of the difference people hear between headphone amps/stages is down to output impedance. The effects of varying output impedance can easily be shown and heard and it varies hugely between stages.
    A phone that sounds forthright and direct on one stage can sound recessed and soft on another because the output impedance is altering the transfer function in a non-linear way - certain frequencies are boosted while others are reduced.
    Keith Howard did some testing on this recently in Hi-Fi News and the results were quite dramatic with some phones.
    When looking at headphones, as with loudspeakers it isn't always the headline average impedance figure that is of primary importance but the trends in the impedance curve. A phone that is say 8 ohms at 100hz might reach 30 ohms at 1khz and unless used with an amp having low output impedance it will sound quite different.
    Quote Originally Posted by RobHolt View Post
    OK. To the extent that I understand it, this is no different with speakers. Your amp probably has an output of 8 ohms at the speaker terminals, and while your speakers are rated at 8 ohms average, the actualy impedance curve can vary pretty wildly, presenting a pretty challenging load to the amp. This is certainly the case with my favorite phones, high-ohm Senns. While they are rated at 300 ohms the impedence curve for HD600s, for example, looks like this:
    So what design criteria/specs would one look for to handle such a load? Do I simply look for a headphone amp or head stage in an integrated that is up near the top of the impedence curve? How might that effect the sound if I plugged in a very low impedance set of cans?
    Tim
    I'm Rob.
    That's a high impedance headphone and it will be less affected by the output impedance of typical amps. Pretty much anything half decent should drive it with very little change to the phone's basic tonality.
    !0:1 is a good rule of thumb so given that the headphone doesn't drop below 300 ohms I'd ensure that the driving amp is <30 ohms output impedance.
    Hi Rob.
    Welcome to the Art of Sound.
    I always though headphone amps were basically for folks without a headphone socket on their amp first and foremost. If they sounded better after that it was a bonus.
    I have a Rega Ear headphone amp from 2001 (the one that accompanied the Clamshell range) for sale that I no longer need. It used to drive Sennheiser HD600 headphones, now sold, rather well.
    I'm Rob.
    Quote Originally Posted by Steve Toy View Post
    Hi Rob.
    Thanks Steve.
    The Rega ear is a nice stage and would drive just about any 'phone well.
    Some integrated amps (and pre amps) include a headphone socket but these vary in quality for one main reason. Often they are simply a feed taken from the main speaker line and attenuated. These often have high output impedance and as a result give varying performance depending on the 'phones used. Some however drive the headphone socket via a dedicated circuit and those are usually better.
    Thanks Steve.
    Interesting. The story over on Head-fi has been the opposite, that most modern receivers and integrated amps have dedicated headphone circuits that are based on op amps and have little power behind them and are, therefore, inferior to both dedicated headphone amps and older integrateds/receivers with the main speaker amps stepped down through resistors...particularly with "hard to drive" phones like high-ohm Senns.
    I'm not saying that's accurate. Head-fi is full of contradictions, mythology and hyperbole. I'd really like to find out for myself what to look for. I'm a frequent headphone listener and I'd love to be able to upgrade my speaker and headphone amp with a single purchase. I would assume that in tube amps, a separate circuit powered by op amps would not be the solution, but the main amps stepped down. Is that a fair assumption? And is it also a fair assumption that if I look for headphone sections with out puts at or around 30 ohms, that if I like the sound of the amp, I'll like it through phones?
    ON EDIT: Rob, a lot of amps list a wide range (32 ohms to 600 ohms is not uncommon) for headphone output impedance. I assume they're talking about headphone impedences the amp is appropriate to drive?
    Tim
    Hi Rob,
    I echo Steve's comments - welcome to the forum
    Please continue to offer your thoughts and opinions on all aspects of hi-fi. When reading your posts on PFM I often agree with much of what you write, although perhaps not quite so much when it comes to the subject of cables
    Can you tempt Markus to venture over, too? I enjoy his Teutonic ramblings
