The original point of the debate
StanlyB.
To be frank, I don’t think you have managed to follow the qualification and reasoning in my posts. There has been no “backtracking”. If you find my style of writing and reasoning hard to follow then I can only apologies and attempt to keep it simpler.
The point in question is whether or not you or anyone else can tell the difference between a Flac file and a Wav file when played through the same medium.
You say you can.
Not only do you say you can but you say you can primarily because of the qualities of the Dac you make.
However, it seems the vast majority of audiophiles can’t.
In fact, you are the only person I have yet to come across that states they can hear such a difference.
Attempting to gather forum support through being an established member having made a bit of a fool of oneself is a very old and generally despised tactic.
If you are unable to stand up for yourself StanlyB using polite/humorous/intelligent/informed points of discussion then I suggest you pass this debate by.
Single spur balanced Mains. Self built music server with 3 seperate linear PSU, Intel i5, 16 GB RAM no hard drive (various Linux OS). Benchmark Dac2 HGC, single ended XLR interconnects/Belkin cable. Exposure 21RC Pre, Super 18 Power (recap & modified). Modded World Audio HD83 HP amp. Hand built Monitors with external crossovers , Volt 250 bass & ABR, Scanspeak 13M8621 Mid & Scanspeak D2905/9300 Hi. HD595 & Beyer 880 (600 ohm) cans.
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts.
-Bertrand Russel
John.
