I'm Dennis.
I have two, one for the Hi-Fi and another for the studio rack. They are made from high quality plywood, with liberal applications of polyurethane. Insulation is not a direct concern, the sockets being Duraplug 'rubber'.
I would post pictures but I am a muppet with that.
I'm Dennis.
No, sorry I am having a bad period; I plugged in my AVI S200 today and the power supply went puff.
This after my ATC pre and power amp developed a fault last week and went back to them.
Mine are plywood with screw on 5amp Duraplug sockets in all positions but one, that other being a Duraplug 13 amp to allow further extensions of low current equipment to be added, by adding one of those you show in the link.
BTW they self destruct, the screw mountings come off. Plastic 4mm threaded 'barrels' have to be superglued in place and ground perspex peppered onto the joint to beef it up. I have three 0.1microF caps across the three terminals as a filter in my wooden boards. For the studio I only use 13 amp Duraplugs because the currents are so small.
Ah, so the mains connectors are BS546 3-pin 5A type. That's OK, Duraplug use rubber for the insulation.
I was more concerned that you were using wood as the insulation, and whilst dry wood can have a resistivity of around 1014 to 1016 Ohm.m, (compared to hard rubber with a resistivity of 1013 Ohm.m), I wouldn't want to depend on that for anything related to the mains; especially as it could absorb moisture over time and start to track.
I'm Dennis.
Yes, I love the 5A round pins because the chances of getting good contact with them is much higher than with a 13A square pin; only a degree off a right angle, and the contact area is infinitely small.
dont believe that report.
never will believe that any fuse change can be picked up by the human ear.
then again i feel the same about so called directional cables and cable burn in!
imo, "burn in" is our ears and brains perception as they "get used" to the sound.
i do believe that any circuit using caps will have a burn in period, but thats it.
DIGITAL:flac/pc/foobar/wasapi>Chord Qutest> Frans' (Solderdude) headphone correction filter>Violectric V200>Senn HD650, Beyer DT1990
>or Garage 1217 Project Ember (as pre)>Rega Elex-R>Dynaudio M10.
ANALOGUE: Rega P8>Rega Aria> Rega Elex-R>Dynaudio M10
