Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Big Bottle MkIII Phono stage
    I'm Kevin.
    Populated PCB
    Checking MM mode
    Mock up
    Rear panel fully populated
    A sneak peak of the semi-finished look
    Kevin
    I'm Keith.
    Thanks for posting pictures Kevin it looks to be coming along nicely.
    I'm Kevin.
    No problem.
    I hope to have it finished pretty soon. I have a day off on Monday, so if the weather is as good as it is now, and there are not too many interruptions, I may get it finished then.
    I do need to remove the BB3 PCB to solder in my “pure silver” occ signal wires, as all the important connections will be direct to the board. I think it only needs a few more hours, and then it will be done.
    Kevin
    I'm Kevin.
    The missing bits turned up today, so I have completed the build.
    All signal wiring is Neotech UP-OCC silver cable. Power cable is Neotech UP-OCC copper.
    All RCA sockets are pure copper, gold plated. I am not sure I would recommend them though, as they need a lot of heat to solder the cable on.
    This thing sounds awesome. It is going to need a fair few hours for it to settle in.
    To initially power it up, I used a Reflektor 6N2P and some National PCC88 valves, so there is more to come from a change to better valves.
    Kevin
    I'm Kevin.
    An update. As the weather was not great, I spent a lot of time listening to vinyl at the weekend.
    I really enjoyed the phonostage in my Firebottle Kin, but the BB Mk.III (also designed by Mr Firebottle) shows that his designs have evilved, and there is a clear and obvious improvement.
    I know that this next bit is a bit of a Cliché, but I was hearing detail I was not aware of before. There is a great 3D image, plenty if space around the instruments and good timbre and clarity.
    I am well chuffed with it. If you get a chance to listen to one, be careful, as you may want one afterwards....
    Kevin
    I'm Kevin.
    I have been browsing various sites recently, look for some “genuine” Telefunken PCC88 valves before prices got too silly.
    I was shocked to see the prices, so I decided to wait until I got home to check the stock.
    I am glad I did, as there are two sat in my spare valve box.
    With the expected valve lifetime, I think I have enough quality valves to keep the BB3 running to see me out.
    Kevin
