Results 1 to 10 of 11
Thread: FS; Ortofon M20FL
    I'm Rodger.
    Default FS; Ortofon M20FL
    Unused Nos Ortofon M20FL Moving Iron cart , acquired a few months back from William Thacker and Never mounted , Ergo Zero hours on the clock .These were 124/130 dep on current exch rate + shipping .
    This thread on Vinyl engine was the cataylist http://www.vinylengine.com/phpBB2/viewtopic.php?t=23259
    Looking for 90 + 5 recorded PP to UK
    I'm John.
    Default Ortofon M20 FL Super
    Was trying to follow your link to the Vinyl Engine but access was denied. Too much spam apparently.
    SME Model 15/Series V, Ortofon 2M Black. Technics SL1200 with SME M2-9 and Ortofon 2M Black. Mike New bearing/platter. Isonoe feet. Timestep PSU. Achromat. Dynavector P75III phono. Naim Supernait/HiCap. Oppo UDP 205 Blu Ray, CD, SACD, DVD-A disc spinner. Spendor S5e speakers. BAP mains block. Various mains/interconnects. Tube Distinctio,ns Mains power filter courtesy Mark Grant. D-I-Y bamboo shelves with cone feet.
    I'm Rodger.
    Quote Originally Posted by prestonchipfryer View Post
    Thanks for the heads up VE link repaired .
    It's a good-un, likes higher mass arms and is tonally very even indeed. I love mine lots... Best fitted with the Cap 210 I think.
    Good luck with the sale
    I'm King.
    Are you sure about that?
    The Ortofon M20FL Super has a compliance of around 20cu which suggests it will need a low to medium mass arm for the best results.
    King
    I'm Rodger.
    Quote Originally Posted by kcc123 View Post
    For sure King , I bought this one up as a back up cart on an SP10/EPA100 setup mainly due to the favourable buzz over on VE , Unfortunately never gotten around to setting her up and must bow to your user experiences there Dave .
    Compared to the VMS and earlier M series (including the M20E Super version [not the Dual one, as this is a custom-OEM VMS20e sibling]), the M20 FL Super can track at 1.5 - 1.7 grammes and to get the best sense of "air" from it, I tried increasing the arm effective mass from 13g approx to around 20g estimated. Groove stability wasn't overtly affected and the sense of 3-D inproved hugely to my ears.
    This Ortofon was an oddball from their late seventies range, as most of the others were highly compliant as was the "replacement" VMS30, which wasn't as good IMO.
    Arms like the Jelco 750 series, and my experiences with the FR64 and even the maligned Thorens TP16 and Lenco L75 tonearms, work surprisingly well with cartridges they're *not* supposed to work with. Only severely warped records, or badly set up springy belt driven wonders, will cause upsets I find.
    I'm King.
    Well, in this case, I will mount my two M20 FL Supers on two different mass arms or in two different mass headshells and compare. No disrespect to you, Dave, but I am just curious.
    King
    Please do so. The Dual 701 tonearm is probably not a fair thing to use, but I rather preferred it mass loaded and that's how mine is set up on its headslide... The E version was definitely for low mass arms and the standard 701 arm was slightly too heavy for it.
    I'm Rodger.
    Price adj 85 + 5 recorded delivery UK
